Is it possible to apply a scale factor to all keyboard inputs for all commands?
For Example, Lets say the scale factor is .5. When your run a command such as the offset command, if you type 100 for the offset distance it would actually offset 50 units in the drawing. Same thing with the line command, draw a line by typing 100 on the keyboard and it would draw a line 50 units in the drawing.
