Author Topic: {Resolved}How to find the duplicate items in the list  (Read 13684 times)
xiaxiang
Re: {Challenge}How to find the duplicate items in the list
« Reply #15 on: January 15, 2015, 04:34:51 AM »
OK, here's an iterative + imperative attempt by first sorting the list:
_$ (List:DuplicatesEq2 '(1.0 1.1 1.19 1.2 1.21 1.22 1.23 1.25 1.3 ) 0.05)
((1.19 1.2 1.21 1.22 1.23 1.25))
_$ (List:DuplicatesEq2 '(1.0 1.1 1.19 5.0 5.01 4.98 1.2 1.21 1.22 1.23 1.3) 0.05)
((1.19 1.2 1.21 1.22 1.23) (4.98 5.0 5.01))
Minor error
(List:DuplicatesEq2 '(1.0 1.1 1.19 1.2 1.2 1.21 1.22 1.23 1.25 1.3 2.0 2.1 2.19 2.2 2.2 2.21 2.22 2.23 2.25 2.3) 0.05)
-->((1.19 1.2 1.2 1.21 1.22 1.23 1.25) (2.19 2.2 2.2 2.21 2.22 2.23 2.25 2.3))
« Last Edit: January 15, 2015, 04:51:30 AM by xiaxiang »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #16 on: January 15, 2015, 04:40:37 AM »
Minor error
-->((1.19 1.2 1.2 1.21 1.22 1.23 1.25) (2.19 2.2 2.2 2.21 2.22 2.23 2.25 [color=red]2.3[/color]))
On my comp:
  (equal 2.25 2.3 0.05);=>> T
  (equal 2.15 2.2 0.05);=>> nil
  (equal 2.05 2.1 0.05);=>> nil
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #17 on: January 15, 2015, 04:43:26 AM »
my version for sorted list:
  1. (defun f (l a b)
  2.   (cond ((and (not l) (cdr b)) (list (reverse b)))
  3.         ((not l) nil)
  4.         ((equal (car l) (car b) a) (f (cdr l) a (cons (car l) b)))
  5.         ((cdr b) (cons (reverse b) (f l a nil)))
  6.         ((f (cdr l) a (list (car l))))
  7.   )
  8. )
test:
  1. (f (vl-sort l '<=) a nil)
xiaxiang
« Reply #18 on: January 15, 2015, 04:55:33 AM »
  1. (defun f (l a b)
  3.         ((not l) nil)
  7.   )
  8. )
test:
What is "a" and "b"? :-o
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #19 on: January 15, 2015, 05:03:37 AM »
(f (vl-sort '(1.0 1.1 1.19 1.2 1.2 1.21 1.22 1.23 1.25 1.3 2.0 2.1 2.19 2.2 2.2 2.21 2.22 2.23 2.25 2.3)  '<=) 0.05 nil)
VovKa
  • Ukraine
« Reply #20 on: January 15, 2015, 05:49:00 AM »
On my comp:
but
(equal 2.25 (+ 2.25 0.05) 0.05);=>> T
(equal 2.15 (+ 2.15 0.05) 0.05);=>> T
(equal 2.05 (+ 2.05 0.05) 0.05);=>> T
damn nice surprise from autodesk programmers :)
Marc'Antonio Alessi
  • Marco
« Reply #21 on: January 15, 2015, 06:05:00 AM »
Sorry for the intrusion, but there is something I do not understand. If we, for example, stating that this function is reliable:
;; Unique with Fuzz  -  Lee Mac
;; Returns a list with all elements considered duplicate to
;; a given tolerance removed.
(defun LM:UniqueFuzz ( l f / x r )
    (while l
        (setq x (car l)
              l (vl-remove-if (function (lambda ( y ) (equal x y f))) (cdr l))
              r (cons x r)
    (reverse r)
(LM:UniqueFuzz     '(1.0 1.1 1.19 1.2 1.21 1.22 1.23 1.25 1.3) 0.05)
=>                  (1.0 1.1 1.19                    1.25 1.3)
So: (1.2 1.21 1.22 1.23) are duplicates? This is the required result?
; 20150114 - 1.00 - only for test
(defun ALE_List_FindDupesFuzz (In_Lst FuzFac / OutLst TmpLst NthVal Countr)
    (setq OutLst (list (car In_Lst)) In_Lst (cdr In_Lst))
    (foreach ForElm In_Lst
      (if (vl-position ForElm OutLst)
        OutLst
          (setq Countr 0)
          (while (and Countr (setq NthVal (nth Countr OutLst)))
            (if (equal ForElm NthVal FuzFac)
              (setq Countr nil)
              (setq Countr (1+ Countr))
          (if NthVal
            (setq TmpLst (cons ForElm TmpLst))
            (setq OutLst (cons ForElm OutLst))
    (reverse TmpLst)
(ALE_List_FindDupesFuzz '(1.0 1.1 1.19 1.2 1.21 1.22 1.23 1.25 1.3) 0.05)
xiaxiang
« Reply #22 on: January 15, 2015, 06:38:37 AM »
(1.19 1.2 1.21 1.22 1.23 1.25) are duplicate items in my case.The next step we will determine which value that was considered as duplicate should be reserved.
Marc'Antonio Alessi
  • Marco
« Reply #23 on: January 15, 2015, 09:10:48 AM »
Ok, this may be a foreach version:
(ALE_List_FindDupesFuzz '(1.0 1.1 1.19 1.2 1.21 1.22 1.23 1.25 1.3) 0.05)  => (1.19 1.2 1.21 1.22 1.23 1.25)
; 20150115 - 1.03
      (or (vl-position ForElm TmpLst) (setq TmpLst (cons ForElm TmpLst)))
        (setq Countr 0)
          (if (equal ForElm NthVal FuzFac) (setq Countr nil) (setq Countr (1+ Countr)))
        (or
          Countr
            (or  (vl-position NthVal TmpLst) (setq TmpLst (cons NthVal TmpLst)))
            (and (vl-position NthVal OutLst) (setq OutLst (vl-remove NthVal OutLst)))
        (if NthVal (setq TmpLst (cons ForElm TmpLst)) (setq OutLst (cons ForElm OutLst)))
  (reverse TmpLst)
« Reply #24 on: January 15, 2015, 09:34:14 AM »
Minor error
On my comp:
Same here .. that's not cool.
Marc'Antonio Alessi
  • Marco
« Reply #25 on: January 15, 2015, 09:49:47 AM »
Minor error
On my comp:
(equal 2.25 2.30 0.05)                ;=>> T
(equal 2.25 2.30 0.049999999999999)   ;=>> nil
(equal 2.25 2.30 0.0499999999999999)  ;=>> T
(equal 2.15 2.2 0.05)                 ;=>> nil
(equal 2.15 2.2 0.0500000000000001)   ;=>> nil
(equal 2.15 2.2 0.050000000000001)    ;=>> T
Marc'Antonio Alessi
  • Marco
« Reply #26 on: January 15, 2015, 11:59:35 AM »
there is still something wrong...
(setq fuzz 0.05   alist '(3.0 1.0 1.1 1.19 1.2 1.21 1.22 3.0 3.0 3.0 3.0 3))
=> (3.0 1.0 1.1 1.19 1.2 1.21 1.22 3.0 3.0 3.0 3.0 3)
(ALE_List_FindDupesFuzz alist fuzz)  >>>  r.1.03
=>  (1.19 1.2 1.21 1.22 3.0 3)
(f (vl-sort alist  '<=) fuzz nil)
=> ((1.19 1.2 1.21 1.22) (3 3.0 3.0 3.0 3.0 3.0))
(List:DuplicatesEq alist fuzz)
=> (3.0 1.19 1.2 1.21 1.22 3.0 3.0 3.0 3.0 3)
roy_043
  • BricsCAD 18
« Reply #27 on: January 15, 2015, 01:10:37 PM »
On my comp:
but
This problem is caused by the fact that the 64 bit binary floating point format cannot be exactly matched to the decimal format.
xiaxiang
Re: {Resolved}How to find the duplicate items in the list
« Reply #28 on: January 19, 2015, 10:05:16 PM »
Thank you all !
 :-D :-D :-D
Marc'Antonio Alessi
  • Marco
« Reply #29 on: January 20, 2015, 08:47:01 AM »
IMHO, I think to properly terminate this thread need to distinguish three types of "ListDupesFuzz" functions:
=> fuzz 0.05
Remove Uniques: (1.0 1.1 1.19 1.2 1.21 1.22 1.23 1.25 1.3 3.0 3.0 3.0)
              =>(1.2              1.21 1.22 1.23)
Show     Dupes: (1.0 1.1 1.19 1.2 1.21 1.22 1.23 1.25 1.3 3.0 3.0 3.0)
             => (        1.19 1.2 1.21 1.22 1.23 1.25     3.0)
Show All Dupes: (1.0 1.1 1.19 1.2 1.21 1.22 1.23 1.25 1.3 3.0 3.0 3.0)
             => (        1.19 1.2 1.21 1.22 1.23 1.25     3.0 3.0 3.0)
