Author Topic: {Resolved}How to find the duplicate items in the list  (Read 13584 times)
xiaxiang
Re: {Resolved}How to find the duplicate items in the list
« Reply #30 on: January 20, 2015, 08:23:50 PM »
IMHO, I think to properly terminate this thread need to distinguish three types of "ListDupesFuzz" functions:
=> fuzz 0.05
Remove Uniques: (1.0 1.1 1.19 1.2 1.21 1.22 1.23 1.25 1.3 3.0 3.0 3.0)
              =>(1.2              1.21 1.22 1.23)
Sorry but I couldn't understand the function "Remove Uniques".
Why does it return (1.2 1.21 1.22 1.23)?
In fact I could not state the situation of the duplicate items exactly yet.
Marc'Antonio Alessi
  • Marco
« Reply #31 on: January 21, 2015, 03:49:50 AM »
My apologies the exact result is:
              =>(             1.2 1.21 1.22 1.23              3.0 3.0)
You can understand what I meant if you see my previous post: http://www.theswamp.org/index.php?topic=48646.msg537421#msg537421
(LM:UniqueFuzz ' (1.0 1.1 1.19 1.2 1.21 1.22 1.23 1.25 1.3 3.0 3.0 3.0) 0.05)
                 (1.0 1.1 1.19  ^   ^    ^     ^  1.25 1.3 3.0  ^   ^ )
Remove Uniques:=>(             1.2 1.21 1.22 1.23              3.0 3.0)
I do not know if I can explain well: in the case above the item "1:19" is unique in the  out list of LM:UniqueFuzz but but just because it is the first that the function processes:
(LM:UniqueFuzz '(1.0 1.1 1.19 1.2 1.21 1.22 1.23 1.25 1.3 3.0 3.0 3.0) 0.05)
              =>(1.0 1.1 1.19  ^   ^    ^     ^  1.25 1.3 3.0  ^   ^ )
(LM:UniqueFuzz '(1.0 1.1 1.2 1.21 1.22 1.23 1.25 1.3 3.0 1.19 3.0 3.0) 0.05)
              =>(1.0 1.1 1.2  ^    ^    ^   1.25 1.3 3.0  ^    ^   ^ )
irneb
« Reply #32 on: January 21, 2015, 06:07:18 AM »
Here's another idea
  1. (defun group-duplicates  (L fuzz / aL grp sem)
  2.   (foreach item  L
  3.     (if (setq grp (assoc (setq sem (fix (/ item fuzz))) aL))
  4.       (setq aL (subst (cons sem (cons item (cdr grp))) grp aL))
  5.       (setq aL (cons (list sem item) aL))))
  6.   (setq aL (vl-sort aL (function (lambda (a b) (<= (car a) (car b)))))
  7.         L nil)
  8.   (while aL
  9.     (setq L (cond
  10.               ((and L (= (1+ (caar L)) (caar aL)))
  11.                (cons (cons (caar aL) (append (cdar aL) (cdar L))) (cdr L)))
  12.               (T (cons (car aL) L)))
  13.           aL (cdr aL)))
  14.                    (vl-remove-if (function (lambda (a) (<= (length a) 2))) L))))
Basically it uses the same principle as I've done in another duplicate finder: http://www.revitforum.org/third-party-add-ins-api-r-d/19248-find-duplicate-items.html
That one was finding "fuzz" duplicate items in Revit through the Dynamo visual programming language, but extended using IronPython to make use of hash table equality matching. In this example I'm using Lisp's built in association list instead of a hash table - actually pretty sad that Lisp doesn't have this capability (makes for huge speed increases in some situations).
Marc'Antonio Alessi
  • Marco
« Reply #33 on: January 21, 2015, 08:36:21 AM »
Here's another idea
Is it right?
(setq fuzz 0.05   alist '(1.0 1.1 1.19 1.2 1.21 1.22 1.23 1.25 1.3 3.0 3.0 3.0))
=> (1.0 1.1 1.19 1.2 1.21 1.22 1.23 1.25 1.3 3.0 3.0 3.0)
(group-duplicates alist fuzz)
=> ((1.1 1.19 1.2 1.21 1.22 1.23 1.25 1.3) (3.0 3.0 3.0))
(equal 1.1 1.0  0.05) => nil
(equal 1.1 1.19 0.05) => nil
(equal 1.3 1.25 0.05) => nil
(equal 1.3 3.0  0.05) => nil
irneb
« Reply #34 on: January 21, 2015, 09:01:10 AM »
Is it right?
Following ... as I understand this:
This one I do see that I make a mistake. Will have to look at how to get around it without making a huge extra iteration just for that edge case.
Floating point inacuracies. I use a division on the fuzz, that's why in my defun that is considered equal. It's just an implementation issue.
I don't understand. Isn't that exactly what my defun did?
Marc'Antonio Alessi
  • Marco
« Reply #35 on: January 21, 2015, 09:17:07 AM »
Yes, I just wanted to say that:
for 1.1 >>> 1.0  is the the nearest lower (equal 1.1 1.0  0.05) => nil
for 1.1 >>> 1.19 is the closest top       (equal 1.1 1.19 0.05) => nil
for 1.3 >>> 1.25 is the the nearest lower (equal 1.3 1.25 0.05) => nil
for 1.3 >>> 3.0  is the closest top       (equal 1.3 3.0  0.05) => nil
irneb
« Reply #36 on: January 21, 2015, 09:20:18 AM »
So here goes my 2nd attempt at the association list method:
  1. (defun group-duplicates1  (L fuzz / aL grp sem mx mn)
  2.   (foreach item  L
  6.   (setq aL (vl-sort aL (function (lambda (a b) (>= (car a) (car b)))))
  7.         L (list (car aL))
  8.         aL (cdr aL))
  9.   (while aL
  10.     (setq mx (cond ((= (length (car L)) 2) (cadar L)) (T (apply 'max (cdar L))))
  11.           mn (cond ((= (length (car aL)) 2) (cadar aL)) (T (apply 'min (cdar aL))))
  12.           L (cond
  13.               ((equal mx mn fuzz)
  14.                (cons (cons (caar aL) (append (cdar aL) (cdar L))) (cdr L)))
  15.               (T (cons (car aL) L)))
  16.           aL (cdr aL)))
  17.   (mapcar (function (lambda (a) (reverse (cdr a))))
  18.           (vl-remove-if (function (lambda (a) (<= (length a) 2))) L)))
Seems to work:
_$ (group-duplicates1 '(1.0 1.1 1.19 1.2 1.21 1.22 1.23 1.25 1.3 3.0 3.0 3.0) 0.05)
((1.19 1.2) (1.25 1.21 1.22 1.23) (3.0 3.0 3.0))
Sorts out even the cases where the divide turned the floating point error arround from what the equal did.
irneb
« Reply #37 on: January 21, 2015, 09:28:56 AM »
Seems to work:
Hang-on ... that's even worse isn't it!
Back to the drawing board  :oops:
irneb
« Reply #38 on: January 21, 2015, 09:38:59 AM »
OK, 3rd attempt ... this time it does seem to produce the correct result. I was going all wrong due to the added optimization I tried by sorting in reverse order to omit one of the reverse calls.
  1. (defun group-duplicates2  (L fuzz / aL grp sem mx mn)
  2.   (foreach item  L
  8.         aL (cdr aL))
  9.   (while aL
  10.     (setq mx (apply 'max (cdar aL))
  11.           mn (apply 'min (cdar L))
  12.           L (cond
  14.                (cons (cons (caar aL) (append (cdar L) (cdar aL))) (cdr L)))
  16.           aL (cdr aL)))
This looks much more like it:
_$ (group-duplicates2 '(1.0 1.1 1.19 1.2 1.21 1.22 1.23 1.25 1.3 3.0 3.0 3.0) 0.05)
((1.19 1.2 1.21 1.22 1.23 1.25) (3.0 3.0 3.0))
« Last Edit: January 21, 2015, 09:45:32 AM by irneb »
Marc'Antonio Alessi
  • Marco
« Reply #39 on: January 21, 2015, 10:43:39 AM »
Another simple version (perhaps too simple), not very tested...
(defun ALE_List_ShowDupesFuzz (In_Lst FuzFac / For001 For002 OutLst)
  (foreach ForElm (mapcar '(lambda (x) (nth x In_Lst)) (vl-sort-i In_Lst '<))
    (and
      (or (equal ForElm For001 FuzFac) (and For001 (equal For001 For002 FuzFac)))
      (setq OutLst (cons For001 OutLst))
    (setq For002 For001 For001 ForElm)
  (if (equal For001 For002 FuzFac) (reverse (cons For001 OutLst)) (reverse OutLst))
(ALE_List_ShowDupesFuzz alist fuzz)
=>(1.19 1.2 1.21 1.22 1.23 1.25   3.0 3.0 3.0)
Marc'Antonio Alessi
  • Marco
« Reply #40 on: January 22, 2015, 12:21:13 PM »
With the same concept can also do the reverse version:
; Function: ALE_List_RemoveAllDupesFuzz - Version 1.01 - 2015/01/21
(defun ALE_List_RemoveAllDupesFuzz (In_Lst FuzFac / For001 For002 OutLst )
    (and
      For001
      (or
        (equal ForElm For001 FuzFac) (equal For001 For002 FuzFac)
  (if (equal For001 For002 FuzFac) (reverse OutLst) (reverse (cons For001 OutLst)))
                     =>  (1.0 1.1                              1.3)
