Author Topic: Hatches being moved to back and transaction Abort causes AutoCAD crash  (Read 2429 times)
I am working on something to explode blocks to a certain depth.  Once I have done that, I go to move all hatches in model space to the back through the DrawOrderTable object associated with the BlockTableRecord.  In a certain drawing it always cause the error "Error handler re-entered. Exiting now." where the message box is titled "AutoCAD Error-abort".  This leads me to assume the error is within AutoCAD's core, as I cannot trap the error with a Try/Catch block.  If I erase all the hatch entities, then the error goes away.  If I use Commit on the transaction, there is no issue.  But if I use Abort, which I have to to get all the items back to their original state, then the error happens every time.
I cannot post the code or drawing, but was wondering if I am thinking wrong? or if I should pass this one on to AutoDesk? or is there any way I can get the drawing back to it's original state before I started my command?
Thanks in advance.
Edit:  I should point out that the program works fine in all other drawings tested, just this one has issues with the hatch patterns.  Even if I Audit the file first.
« Last Edit: January 12, 2015, 12:49:42 PM by T.Willey »
I have another drawing that exhibits this characteristic.  I have narrowed down the problem to a selection of 3 hatches and some circles.   The code posted will crash Autocad every time in this drawing.  If I changed the call from 'dot.MoveToBottom()' to 'dot.MoveToTop()' then everything works as it should.
Passing true or false to aRemoveAssoc does not matter.
Any help is appreciated.
Thanks in advance,
Code - C: [Select]
  1. [ CommandMethod( "BackCrash" ) ]
  2. public void HatchBackCrash() {
  3.     Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
  4.     Database db = doc.Database;
  5.     BlockTable bt;
  6.     using ( Transaction trans = db.TransactionManager.StartTransaction() ) {
  7.         bt = trans.GetObject( db.BlockTableId, OpenMode.ForRead, false, true ) as BlockTable;
  8.         moveHatchBack( trans, bt[ "*MODEL_SPACE" ], true );
  9.         trans.Abort();
  10.     }
  11. }
  12.
  13. public static void moveHatchBack ( Transaction aTrans, ObjectId aBtrId, bool aRemoveAssoc ) {
  14.         DBObject obj;
  15.         DrawOrderTable dot;
  16.         BlockTableRecord btr;
  17.         Hatch hat;
  18.         ObjectIdCollection hatIds = new ObjectIdCollection();
  19.         btr = aTrans.GetObject( aBtrId, OpenMode.ForRead, false, false ) as BlockTableRecord;
  20.         foreach ( ObjectId oid in btr ) {
  21.             if ( oid.IsErased || oid.IsNull || oid.IsEffectivelyErased || !oid.IsValid ) continue;
  22.                 obj = aTrans.GetObject( oid, OpenMode.ForRead, false, false ) as Hatch;
  23.                 if ( obj == null ) continue;
  24.                 hatIds.Add( oid );
  25.                 hat = obj as Hatch;
  26.                 if ( aRemoveAssoc && hat.Associative ) {
  27.                     hat.UpgradeOpen();
  28.                     hat.Associative = false;
  29.                     hat.DowngradeOpen();
  30.                 }
  31.         }
  32.         if ( hatIds.Count > 0 ) {
  33.                 dot = aTrans.GetObject( btr.DrawOrderTableId, OpenMode.ForWrite, false, false ) as DrawOrderTable;
  34.                  dot.MoveToBottom( hatIds );
  35. //              dot.MoveToTop( hatIds );
  36.                 dot.DowngradeOpen();
  37.         }
  38.         hatIds.Dispose();
  39. }
  40.
MexicanCustard
Tim, what happens if you let the transaction fall through the using clause and go out of scope instead of aborting?
It stills crashes Autocad.
