Author Topic: Invisible viewport  (Read 13738 times)
bbarron281
Re: Invisible viewport
« Reply #15 on: January 09, 2015, 11:38:06 AM »
I wasn't the original author of this CAD file. I was wrong about creating a new viewport to avoid this problem. The new one that I just created is invisible too. It's on its own "viewport" layer which is on and thawed. The color of the layer is different from the background color which is black. I created the viewport by drawing a polygon so I know it's not bigger than what's viewable on screen. Still stumped. I feel like you might know the solution, ronjonp.
« Reply #16 on: January 09, 2015, 11:40:21 AM »
Can you post your drawing ? Also .. try the code I posted in my previous response.
« Reply #17 on: January 09, 2015, 11:42:03 AM »
eagerly                   awaiting             a              sample             of                  this                    suspect                   file
« Reply #18 on: January 09, 2015, 11:43:25 AM »
Ron, in 2006
Command: (defun c:foo ( / i )
(_>      (repeat (setq i (sslength (ssget "_x" '((0 . "viewport")))))
((_>        (vlax-put (vlax-ename->vla-object (ssname ss (setq i (1- i))))
'visible -1)
((_>      )
(_>      (princ)
(_>     )
C:FOO
Command: foo
; error: bad argument type: lselsetp nil
bbarron281
« Reply #19 on: January 09, 2015, 11:43:38 AM »
I don't feel comfortable posting the drawing...work related stuff, you know. Let me know if I ran the code right. I copied it to notepad, saved it as .lsp, appload in autocad, executed "foo" command.
I have limited experience in lisp routines so I think it's likely I missed or messed up a step. But after the command nothing changed, not in respect to the invisibility of the viewport anyway.
« Reply #20 on: January 09, 2015, 11:46:01 AM »
save the file with a NEW NAME
ERASE everything other than the SICK Viewport.....easy enough to remove ALL TRACE of who, or what the file is about.
Or don't you want this resolved?
bbarron281
« Reply #21 on: January 09, 2015, 11:47:29 AM »
Here's a stripped down version. There are two viewports. One can be seen in the bottom and the one above it is invisible.
« Reply #22 on: January 09, 2015, 11:57:03 AM »
Ron, in 2006
'visible -1)
((_>      )
(_>      (princ)
(_>     )
C:FOO
Command: foo
That's what happens when I don't test it :oops:
  1. (defun c:foo (/ i ss)
  2.   (setq ss (ssget "_x" '((0 . "viewport"))))
  3.   (repeat (setq i (sslength ss))
  4.     (vlax-put (vlax-ename->vla-object (ssname ss (setq i (1- i)))) 'visible -1)
  5.   )
  6.   (princ)
  7. )
Although it does not fix the OP drawing.
« Reply #23 on: January 09, 2015, 12:11:29 PM »
time to delete that particular viewport and move on
bbarron281
« Reply #24 on: January 09, 2015, 12:32:37 PM »
Already have. This error has reoccurred with the new viewport that I created as well. The explanation I will get from my supervisor is that it's an error in the drawing. This seems like a bit of a cop-out explanation to me but that's probably because I'm stubborn and want a reason for everything. I'll figure out a way around it though. Thanks for the help, everyone.
Bethrine
« Reply #25 on: January 09, 2015, 12:54:14 PM »
Even when I'm clicked into the viewport, zoom moves paperspace.
« Reply #26 on: January 09, 2015, 12:58:19 PM »
Bethrine; your issue is the viewport is LOCKED a good thing.
bbarron281
This worked here
I wblocked/deleted the viewport into a new dwg
it opens and knows it is still a viewport yet it displays
then copied with basepoint
and pasted back to original coordinates in your sample file
it displays and is a viewport once again
now trying to solve WHAT happened to it....to start the issue off
Bethrine
« Reply #27 on: January 09, 2015, 01:01:08 PM »
Ah.  :embarrassed:  :2funny:
bbarron281
« Reply #28 on: January 09, 2015, 01:21:24 PM »
mjfarrell, I've taken the file I provided and qselected the viewport then did the wblock command with a base point. Then in the drawing I'm working with I've run the insert command to the exact base point but I'm not getting anything. I've missed a step here. I rarely use the wblock command so I bet I messed it up.
Matt__W
  • I like my water diluted.
« Reply #29 on: January 09, 2015, 01:48:04 PM »
Looks like someone drew a rectangle, used the VPCLIP command to modify an existing viewport to then use the newly created rectangle, then the rectangle was deleted leaving behind the viewport. I don't know of any way to recreate the viewport outline without some sort of programming wizardry.
Autodesk Expert Elite
