Author Topic: Leader problem cont'd, dwg attached.  (Read 1756 times)
Bethrine
« on: January 08, 2015, 10:29:21 AM »
I am still having this stupid leader problem.  :uglystupid2: See if it duplicates for you? If not then it has to be a setting I can't find.  :x
~Aside: I am much more knowledgeable on dimension styles.  :idea:
ROBBO
Re: Leader problem cont'd, dwg attached.
« Reply #1 on: January 09, 2015, 04:05:04 AM »
Hello Bethrine,
For 3d objects use VIEWBASE instead of viewports. A copy of your drawing re-attached with example of viewbase and dimensions.
This hopefully solves your problem.
Kr. Robbo.
« Last Edit: January 09, 2015, 04:18:09 AM by ROBBO »
The only thing to do with good advice is to pass it on.
It is never of any use to oneself.
Oscar Wilde
(1854-1900, Irish playwright, poet and writer)
Bethrine
« Reply #2 on: January 09, 2015, 09:27:01 AM »
Hello Bethrine,
Kr. Robbo.
I didn't know AutoCAD had that!  :wideeyed2: Thank you!  :-D
ROBBO
« Reply #3 on: January 09, 2015, 09:33:46 AM »
You're Welcome. Glad to help. I think it was introduced in 2012 version.
Oscar Wilde
