Author Topic: Wipeout Trouble  (Read 4274 times)
Re: Wipeout Trouble
« Reply #15 on: January 06, 2015, 11:25:25 AM »
That's just one way to do it (per MJ thoughts). My point in the beginning is hatch can achieve the same effect you're looking for on a single layer and will accept a wider variety of shapes. Plus IMO using the picK internal point option it's much easier to create these areas.
Below is an example that took less than a minute to draft. How long would it take you to draft wipeouts ?  :P
« Last Edit: January 06, 2015, 12:03:48 PM by ronjonp »
craigr
Re: Wipeout Trouble
« Reply #16 on: January 06, 2015, 11:27:16 AM »
Point Taken.
Re: Wipeout Trouble
« Reply #17 on: January 06, 2015, 11:39:37 AM »
Just food for thought. :)
craigr
Re: Wipeout Trouble
« Reply #18 on: January 08, 2015, 11:44:33 AM »
Thinking of this further.....
So if I were to switch to Hatches from Wipeouts, how would I make the background the same color as the background of the rest of the dwg? I know how to make the diagonal background change, but the area NOT being worked on, I want to be the same as  that around it but not show and walls, etc. underneath it. - Basically mimicking a Wipeout.
'Edited' - I don't want the unused area to 'gray'.
I hope you understand what I am trying to ask, I don't know a better way to describe it.
Re: Wipeout Trouble
« Reply #19 on: January 08, 2015, 12:27:37 PM »
Are you talking about on the screen or when you print? If it's on the screen then just use your wipeouts. If it's for printing, you'll have to pick a color and change the screening in your color table to 0%.
cadtag
Re: Wipeout Trouble
« Reply #20 on: January 08, 2015, 01:33:38 PM »
or refuse to mess with your pen tables, then use TrueColor 255,255,255 for the solid hatch.
if you want to get funkier effects, set it to a level of transparency
craigr
Re: Wipeout Trouble
« Reply #21 on: January 08, 2015, 01:36:51 PM »
Just curious.
