Author Topic: Quit vs Exit in AutoLisp  (Read 12156 times)
mailmaverick
« on: December 30, 2014, 07:44:59 AM »
Whats the difference between Quit and Exit in AutoLisp ?
Re: Quit vs Exit in AutoLisp
« Reply #1 on: December 30, 2014, 07:53:28 AM »
Essentially none.
« Reply #2 on: December 30, 2014, 08:18:43 AM »
TIC - One is poor technique and the other is lazy programing.
mailmaverick
« Reply #3 on: December 30, 2014, 08:37:19 AM »
Please explain.
« Reply #4 on: December 30, 2014, 10:07:20 AM »
These are relevant to your question:
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/quit-vs-exit/td-p/836439
http://www.afralisp.net/autolisp/tutorials/cond-vs-if.php
PS
The TIC is Tongue In Cheek and a dated expression meaning an attempt at humor.
Although a poor one I must admit.
« Last Edit: December 30, 2014, 10:11:02 AM by CAB »
« Reply #5 on: December 30, 2014, 10:44:04 AM »
I'd never seen that COND vs IF article on afralisp before; nice link CAB.
I agree with the use of COND over IF; I've had a few arguments over the use of IF vs COND and keeping the namespace hygienic. ...Not to mention the use of a BOOLE in place of a simple COND or IF statement (that drives me batty when the tactic is misused).
If I remember right, I would use QUIT in dialog box situations and not so much in regular application situations (you need to properly set up your error handler environment to handle their use). I assembled "a better error handler", from a few people's efforts. (just search the "show your stuff" forum for my name and error) that should get you started if you wanted to.
mailmaverick
« Reply #6 on: December 30, 2014, 11:47:24 AM »
PS
As per the links shared by you, there is no difference between quit and exit.
However, if AUTOLISP has made these two commands, there has to be a difference.
There cannot be two commands for exactly same thing.
It would be good to know the difference for academic purposes. :-D
« Reply #7 on: December 30, 2014, 11:51:17 AM »
Why does there have to be a difference?
http://theswamp.org/~john/avlisp/#exit
http://theswamp.org/~john/avlisp/#quit
Set up an error handler and test them each.
Bhull1985
« Reply #8 on: December 30, 2014, 12:13:08 PM »
PS
Could it just be that Autodesk assumed when exiting (or quitting) an app that the majority of persons would be accustomed to using one of these two commands?
And rather than to have the "quit"ters receive an 'Unknown command "QUIT". Press F1 for help.'
or
the "exit"ers have the opposite...they just decided to implement both commands for fluidity?
That's what I would guess, especially reading that there are no documented differences at least shown in this thread.
« Reply #9 on: December 30, 2014, 12:41:30 PM »
I completely agree - there are very few cases in which such functions cannot be avoided, in my mind they are the equivalent of resorting to a goto statement to control code evaluation...
Perhaps one of the few situations in which the use of such functions is unavoidable is within a vl-catch-all-apply expression to essentially break evaluation of a vlax-for expression when a certain condition is met in order to avoid unnecessary iteration of an entire collection - but this is also a rare case.
As for the difference between the two, as far as I am aware, there is none. This may seem redundant, but then remember that AutoLISP is a high-level language and consequently there are many functions which are present merely for convenience - after all, any cond expression can be written using a sequence of nested if expressions, any loop could be written using while, 1+/1- are entirely superfluous, etc. etc.
« Reply #10 on: December 30, 2014, 03:22:39 PM »
Quote from: mailmaverick
The links said it.
I said it.
John's excellent avlisp help file for theSwamp saya it
The AutoLisp Help files said it.
Why does there have to be a difference ?
Why ?
Academic pursuits are excellent but you need to check your premises. There is no difference and no amount of assumptions and second guessing will change that.
« Reply #11 on: December 30, 2014, 03:35:58 PM »
I haven't been around AutoLisp / lisp long enough but could it be a legacy issue.
New function name created & old name not removed.
Jeff H
« Reply #12 on: December 30, 2014, 03:36:50 PM »
They are spelled different.
From the Lisp Console
_$ exit
#<SUBR @0000000031fde8b8 QUIT>
_$ quit
_$
So looks like they both evaluate to calling the same subroutine.
« Reply #13 on: December 30, 2014, 07:46:35 PM »
I apologize I am typing this via my phone so I'm keeping this brief.
goto is all together different. Comparing apples to oranges.
I wouldn't say that the functions usage is all that bad either (the goto is a negative connotation); after all they did make vl-exit-with-message.
