Author Topic: Point to LAT LON  (Read 7823 times)
Point to LAT LON
« on: December 19, 2014, 03:31:35 PM »
I've done a little bit of searching for this, but have not found what I've needed. I have a list of points from a GPS unit and would like to convert the LAT & LON to place in a KML file. I used this utility to do the conversion, but would like to know if anyone has come up with a lisp solution.
Thanks.  :)
ymg
Re: Point to LAT LON
« Reply #1 on: December 19, 2014, 03:53:55 PM »
ronjomp,
What format does your GPS gives you ?
They are usually in Lat long.  KML requires Long Lat in decimal degree.
However if you are getting UTM out of your GPS you could use
the projlib library from Prof. David Allison  and transform back to
Lat. Long.
The projlib library in autolisp is part of the following Zip : http://www.usouthal.edu/geography/allison/mappro/mappro.zip
ymg
« Reply #2 on: December 19, 2014, 04:03:16 PM »
YMG,
<Disclaimer>I'm a newbie to this so handholding may be necessary ;)</Disclaimer>
The GPS points were given to me by someone else. The format is as follows:
to Latitude   to Longitude   Latitude   Longitude
33.67   111.0916667   334012   1110530
Thanks for your help.
ymg
« Reply #3 on: December 19, 2014, 05:10:54 PM »
Ronjomp,
To use them in a kml all you need to do is
to use them in reverve order that is long first
as 111.0916667 33.67
For example outputting the following
is sufficient to create a placemark at your point:
<Placemark>
<name>YourPoint</name>
<Point>
<coordinates>111.01966667,33.67,0</coordinates>
</Point>
</Placemark>
note: no space after the comma.
ymg
« Reply #4 on: December 19, 2014, 05:22:24 PM »
The points that were supplied to me are these ones: 334012   1110530
The other points were the converted points from the website above.
I was wondering how to do that?
ymg
« Reply #5 on: December 19, 2014, 05:25:54 PM »
ronjomp,
Very likely to mean 111.0530,33.4012
Long would normally be on the interval -180 to 180
While Lat are on -90 to 90
If you paste the text of the placemark code I gave you
into the Myplaces folder in the side window of GE
your placemark should appear.
Double-click on the placemark and GE will zoom to it.
That would be a place in China, nearest city Shaanxi
ymg
« Last Edit: December 19, 2014, 05:49:54 PM by ymg »
« Reply #6 on: December 19, 2014, 05:39:53 PM »
Maybe a picture will help :) .. How do you calculate the value in yellow?
« Reply #7 on: December 19, 2014, 05:44:40 PM »
use QGIS
Import them
Export them to KML,or KMZ
or many other formats
« Reply #8 on: December 19, 2014, 05:54:43 PM »
Figured it out ( I think )  :)
  1. ;;1110530
  2. ;; (D 111)(M 05)(S 30)
  3. (alert (strcat "111." (vl-princ-to-string (+ (/ 5 60.) (/ (/ 30 60.) 60.)))))
« Last Edit: December 19, 2014, 06:18:48 PM by ronjonp »
« Reply #9 on: December 19, 2014, 05:57:59 PM »
use QGIS
Import them
Thanks for the reply Michael, I'll give QGIS a look.
ymg
« Reply #10 on: December 19, 2014, 06:41:12 PM »
rojomp,
It is simply transforming degree minutes second to decimal degree;
  1. (defun todec (int / str len d m s)
  2.    (setq str (itoa int)
  3.          len (strlen str)
  4.            s (atof (substr str (- len 2)))
  5.            m (atof (substr str (- len 3) 2))
  6.            d (atof (substr str 1 (- len 4)))
  7.    )
  8.    (+ d (/ (+ m  (/ s 60)) 60))
  9. )
  10.
« Last Edit: December 19, 2014, 07:05:15 PM by ymg »
divtiply
« Reply #11 on: December 20, 2014, 07:19:46 AM »
  3.          len (strlen str)
  7.    )
  9. )
  10.
Why not angtof/angtos?
ymg
« Reply #12 on: December 20, 2014, 10:55:20 AM »
divtply,
Your suggestion works also, but this is a carry over from the day of hand calculator.
Angtof returns the result in radians, and the OP needs results in decimal degree.
ymg
« Reply #13 on: December 22, 2014, 10:29:45 AM »
Thanks for the replies YMG. This is what I ended up cobbling together that seems to work.
  1. (defun _kmlpoint (n / d i m s)
  2.   (setq d (* n 0.0001))
  3.   (setq n (rtos (float n) 2 8))
  4.   (setq i (1+ (strlen (itoa (fix d)))))
  5.   (setq m (atof (substr n i 2)))
  6.   (setq s (atof (substr n (+ i 2))))
  7.   (if (minusp d)
  8.     (- (+ (abs (fix d)) (/ m 60.) (/ (/ s 60.) 60.)))
  9.     (+ (fix d) (/ m 60.) (/ (/ s 60.) 60.))
  10.   )
  11. )
  12. ;; (rtos (_kmlpoint -1111007.5) 2 8)
ymg
« Reply #14 on: December 23, 2014, 11:14:55 AM »
ronjomp,
You may have a problem with 03030 as input.
So maybe with a string input intead of an integer:
  1. (defun todec (str / d m s n sig)
  2.    (setq n (strlen str)
  3.          s (atof (substr str (- n 2)))
  4.          m (atof (substr str (- n 3) 2))
  5.          d (abs (atoi (substr str 1 (- n 4))))
  6.        sig (if (wcmatch str "-*") -1 1)
  7.    )
  8.    (* sig (+ d (/ (+ m  (/ s 60)) 60)))
  9. )
  10.
