;;----------------=={ Add Object to Block }==-----------------;;
;; Add single object in the provided ENAME definition to ;;
;; definition of the specified block. ;;
;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;;
;; slightly modified by M.R. for his purposes ;;
;; Arguments: ;;
;; doc - Document Object in which block resides. ;;
;; block - Entity name of reference insert ;;
;; ent - Object to add to definition [ENAME] ;;
(defun LM:AddObjecttoBlock
( doc block ent
/ mat vlaentblk
mat (LM:Ref->Def block)
vlaentblk
;;-----------------=={ Remove From Block }==------------------;;
;; Removes an Entity from a Block Definition ;;
;; Arguments: ;;
;; ent - Entity name of Object to Delete from Block [ENAME] ;;
(defun LM:RemovefromBlock
( doc ent
;;------------------=={ Safearray Variant }==-----------------;;
;; Creates a populated Safearray Variant of a specified ;;
;; data type ;;
;; Arguments: ;;
;; datatype - variant type enum (eg vlax-vbDouble) ;;
;; data - list of static type data ;;
;; Returns: VLA Variant Object of type specified ;;
(defun LM:SafearrayVariant
( datatype data
;;---------------=={ Block Ref -> Block Def }==---------------;;
;; Returns the Transformation Matrix and Translation Vector ;;
;; for transforming Block Reference Geometry to the Block ;;
;; Definiton. ;;
;; Arguments: ;;
;; e - Block Reference Entity ;;
;; Returns: List of 3x3 Transformation Matrix, Vector ;;
(defun LM:Ref
->Def
( e
/ _dxf a l n
(setq l
(entget e
) a
(- (_dxf
50 l
)) n
(_dxf
210 l
(mxv m
(mxm
(list (/ 1.
(_dxf
41 l
)) 0.
0.
) (list 0.
(/ 1.
(_dxf
42 l
)) 0.
) (list 0.
0.
(/ 1.
(_dxf
43 l
(mxm
(1. 0. 0.)
(0. 1. 0.)
(0. 0. 1.)
;;---------------------=={ WCS->Geom }==----------------------;;
;; for transforming Block Definition Geometry to a Block ;;
;; Reference. ;;
;; Arguments: ;;
;; SourceBlock - VLA Block Reference Object ;;
(defun LM:WCS
->Geom
(SourceBlock
/ norm ang x y z
) ;; © Lee Mac 2010
'(x y z)
SourceBlock
prop
alt
'(XEffectiveScaleFactor
YEffectiveScaleFactor
ZEffectiveScaleFactor
'(XScaleFactor YScaleFactor ZScaleFactor)
m
(mxv
m
'((1. 0. 0.) (0. 1. 0.) (0. 0. 1.))
;;-----------=={ Apply Matrix Transformation }==--------------;;
;; Transforms a VLA-Object or Point List using a ;;
;; Transformation Matrix ;;
;; Author: Lee Mac, Copyright © 2010 - www.lee-mac.com ;;
;; Arguments: ;;
;; target - VLA-Object or Point List to Transform ;;
;; matrix - 3x3 Matrix by which to Transform object ;;
;; vector - 3D translation vector ;;
(defun LM:ApplyMatrixTransformation
(target matrix vector
) ;; © Lee Mac 2010
target
'((0. 0. 0. 1.))
target
;; Matrix x Vector - Lee Mac 2010
;; Args: m - nxn matrix, v - vector in R^n
;; Matrix x Matrix - Lee Mac 2010
;; Args: m,n - nxn matrices
;; Matrix Transpose - Lee Mac 2010
(defun c:refeditblkbyname
( / loop def ss i ref defent p el ent entvla
) "BLOCK/XREF"
"Select Block - NOT Xref definition"
(ai_table "BLOCK" 4)
(alert "Selected definition belongs to XREF... Please choose Block definition...") "BLOCK/XREF"
"Model"
;; "_A" mode - excluded objects on frozen layers ;; 410 DXF code quiery for only entities on current space
i 0
1e-8
1e-8
1e-8
4
4
defent
1
1
"_.-REFEDIT"
(LM:ApplyMatrixTransformation
0
1
"Ok"
"_.-REFEDIT"
0
1
"Ok"
