Author Topic: C3D 2015  (Read 12233 times)
C3D 2015
« on: December 15, 2014, 09:25:08 AM »
Maybe its just our setup but this is a very buggy version.
Re: C3D 2015
« Reply #1 on: December 15, 2014, 09:29:26 AM »
After a grueling assessment, it was determined that there was NO compelling reason to even bother installing 2015.
List of NEW features:
Opens 2014 and saves without 'corruption' so that file can be re-opened in 2014.
Everything else....was just fluff.
Re: C3D 2015
« Reply #2 on: December 15, 2014, 09:34:52 AM »
"Official"  List of improvements:
Enhancements to labels - ability to change object reference on labels such as surface contours, slope, spot elevation and alignment station/offset
Profiles
Can create a pass through vertical curve, and then change the constrain parameter to make it based on length or k factor
New Extend Profile command to extend profiles to the end of profile views
New Anchor to Geometry tools.  You can now set profile IP's to move relative to changes in alignment geometry, instead of being based on chainage
Ability to show true section slices through solids on profile views
Corridors
When you replace similar subassemblies, you now have an option to maintain the targets
Improved sampling for width targets - can set up corridor to automatically increase sampling when targets are applied
Corridor solid extraction is now on the ribbon
Sections
Create sample lines now has an option to increment sample lines from a selected start station
Pipes can show cut sections on the section views
Corridor code labels can be included on the section views and now stagger
Can export to KMZ format
Various improvements to Subassembly Composer
All stuff that most of us have found a way to live with already....
the stuff that we have asked to be fixed, like Pipe Networks, gravity, and or pressure Labels, part builder, etc....NOPE nothing there.
Thanks for paying, er I mean playing.
Re: C3D 2015
« Reply #3 on: December 15, 2014, 10:54:24 AM »
The sheet tabs changing positions is quite annoying.
Re: C3D 2015
« Reply #4 on: December 15, 2014, 11:02:09 AM »
This is also annoying:
Fact is this is not a NEW tool only some mods to one that was already in 2014.
BlackBox
Re: C3D 2015
« Reply #5 on: December 15, 2014, 11:10:16 AM »
Are either of you members of the various Civil 3D portals over at beta.autodesk.com?  :-)
Re: C3D 2015
« Reply #6 on: December 15, 2014, 11:14:07 AM »
And this would benefit us how?
And are they taking new members?
Re: C3D 2015
« Reply #7 on: December 15, 2014, 11:56:09 AM »
I am not, no.
BlackBox
Re: C3D 2015
« Reply #8 on: December 15, 2014, 12:07:06 PM »
I am not, no.
You might find it useful, as you have direct access to some of the key staff involved in the product's design, and are often able to test planned enhancements in advance, report bugs, in addition to making feature requests, etc. that others can also vote for.
Cheers
Re: C3D 2015
« Reply #9 on: December 15, 2014, 12:08:37 PM »
Just signed in...SAD
NOTHING for Civil3d (US)  a few things for RSA....although most of us do not live or work in South Africa.
A few entries for Infraworks.....again confirming that they are actually killing support and or development for civil 3d at this time.
Re: C3D 2015
« Reply #10 on: December 15, 2014, 01:02:45 PM »
Michael, not sure where you get the idea they are not developing C3D. I have not been to the main page of the beta.autodesk.com in a long time, so maybe there isn't anything listed there. However, if you would LIKE to be involved in C3D's future, send an email to civil3d.futures@autodesk.com requesting to be added. Note that you will be required to sign an NDA prior to joining, but there is plenty of discussion going on.
Re: C3D 2015
« Reply #11 on: December 15, 2014, 01:05:52 PM »
Mark, get the Hot Fix for this.
Re: C3D 2015
« Reply #12 on: December 15, 2014, 01:10:07 PM »
Sweet! Thank you Jeff.
BlackBox
Re: C3D 2015
« Reply #13 on: December 15, 2014, 01:24:01 PM »
Turn that frown upside down, Michael... Guess I should have mentioned that this is but one of many invitation only portals.  :-D *oops*
Thanks Jeff for posting the email for Civil 3D Futures.
Cheers
Re: C3D 2015
« Reply #14 on: December 15, 2014, 01:24:56 PM »
Cheers
That doesn't make me smile....as humorous as you may think it is.
