Author Topic: foreach loop for every other element  (Read 1499 times)
jt74
« on: December 12, 2014, 03:16:57 PM »
I apologize in advance if my subject is confusing; I'm new to lisp!
I "built" a LSP routine which is 99.9% Lee Mac's Insert Blocks at Intersections script. Basically, the script insert a block at intersections along a polyline and rotate the block to be in line with the polyline at the point of intersection.
The routine functions perfectly, but I need to perform the function at every other intersection, rather than at every intersection.
How can I edit the LSP below (probably the for each line I've marked with ;; < ----- below) to function at every other p?
(defun c:ib ( / a b i j n o s sp )
    (while
            (setvar 'errno 0)
            (initget "Browse")
            (setq s (entsel "\nSelect Block to Insert [Browse]: "))
                (   (= 7 (getvar 'errno))
                    (princ "\nMissed, try again.")
                (   (= "Browse" s)
                    (if (setq n (getfiled "Select Block" (getvar 'dwgprefix) "dwg" 8))
                        (if (tblsearch "BLOCK" (cadr (fnsplitl n)))
                            (null (setq n (cadr (fnsplitl n))))
                        (princ "\n*Cancel*")
                (   (= 'ename (type (car s)))
                    (if (= "INSERT" (cdr (assoc 0 (entget (car s)))))
                        (if (vlax-property-available-p (setq o (vlax-ename->vla-object (car s))) 'effectivename)
                            (null (setq n (vla-get-effectivename o)))
                            (null (setq n (vla-get-name o)))
                        (princ "\nObject is not a block.")
    (setq sp (vlax-get-property (LM:acdoc) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace)))
    (if (and (= 'str (type n)) (setq s (LM:ssget "\nSelect Intersecting Objects: " nil)))
        (repeat (setq i (sslength s))
            (setq a (vlax-ename->vla-object (ssname s (setq i (1- i)))))
            (if (vlax-method-applicable-p a 'intersectwith)
                (repeat (setq j i)
(setq b (vlax-ename->vla-object (ssname s (setq j (1- j)))))
                    (if (vlax-method-applicable-p b 'intersectwith)
                        (foreach p (LM:Intersections a b acextendnone)  ;;;; <--- foreach to be edit to "for every other"
  (setq
 ; esel (entsel "\nSelect Polyline: ")
  ;pol (car esel); the Polyline's entity name
  ;pt (osnap (cadr esel) "nea"); use Osnap to ensure it's really ON the Polyline
  ang
    (angle
      '(0 0 0)
      (vlax-curve-getFirstDeriv
        a
        (vlax-curve-getParamAtPoint a p)
      ); end 1st deriv
    ); end angle & ang
); end setq
                            (vla-insertblock sp (vlax-3D-point p) n 1.0 1.0 1.0 ang)
;;--------------------=={ Intersections }==-------------------;;
;;  Returns a list of all points of intersection between      ;;
;;  two objects for the given intersection mode.              ;;
;;  Author: Lee Mac, Copyright © 2012 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  obj1, obj2 - VLA-Objects                                  ;;
;;  mode       - acextendoption enum of intersectwith method  ;;
;;  Returns:  List of intersection points, or nil             ;;
(defun LM:Intersections ( obj1 obj2 mode / l r )
    (setq l (vlax-invoke obj1 'intersectwith obj2 mode))
    (repeat (/ (length l) 3)
        (setq r (cons (list (car l) (cadr l) (caddr l)) r)
              l (cdddr l)
    (reverse r)
;; ssget  -  Lee Mac
;; A wrapper for the ssget function to permit the use of a custom selection prompt
;; Arguments:
;; msg    - selection prompt
;; params - list of ssget arguments
(defun LM:ssget ( msg params / sel )
    (princ msg)
    (setvar 'nomutt 1)
    (setq sel (vl-catch-all-apply 'ssget params))
    (setvar 'nomutt 0)
    (if (not (vl-catch-all-error-p sel)) sel)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc)
Re: foreach loop for every other element
« Reply #1 on: December 12, 2014, 03:54:10 PM »
Welcome to the Swamp.
maybe this will do:
skips first one & executes every other one
if you want first to execute use (setq tog 1)
              (setq tog 0)
              (if (zerop (setq tog (- 1 tog))) ; note that 1- does not work
                (foreach p (lm:intersections a b acextendnone)
                  (setq
                    ;; esel (entsel "\nSelect Polyline: ")
                    ;;pol (car esel); the Polyline's entity name
                    ;;pt (osnap (cadr esel) "nea"); use Osnap to ensure it's really ON the Polyline
                    ang (angle '(0 0 0) (vlax-curve-getfirstderiv a (vlax-curve-getparamatpoint a p)) ; end 1st deriv
                     ) ; end angle & ang
                  ) ; end setq
                  (vla-insertblock sp (vlax-3d-point p) n 1.0 1.0 1.0 ang)
« Last Edit: December 12, 2014, 03:59:38 PM by CAB »
jt74
« Reply #2 on: December 15, 2014, 03:09:32 PM »
Hiya CAB, and thanks for the response. I very much appreciate your contributions to the Swamp!
Your zerop toggle set me in the right direction. My minor edit to your contribution was to pull the setq tog 0 up and out of the repeat loop within which the if (vlax-method-applicable-p b 'intersectwith condition resides.
Thanks a million.
Here's the ultimate code which will place a block at every other intersection along a polyline and rotate the block to be inline with the polyline:
;; Code is derived from Lee Mac's "Insert Block at Intersection" LSP code.
;; Edits to Lee Mac's code are noted.
;; Thanks to SWAMP contributor CAB for the guiding light!
;;------------=={ Insert Block at Intersections }==-----------;;
;;  Prompts the user to select or specify a block to be       ;;
;;  inserted, and make a selection of intersecting objects.   ;;
;;  Proceeds to insert the specified block at all points of   ;;
;;  intersection between all objects in the selection.        ;;
    (while
            (setvar 'errno 0)
            (initget "Browse")
                (   (= "Browse" s)
    (setq tog 1) ;; <====TOGGLE TO 0 to stagger block placement.      ;; integrated into LM's code for "every other" functionality
(repeat (setq j i)
      (progn ;; Thanks to CAB
                       (if (zerop (setq tog (- 1 tog))) ; note that 1- does not work ;; for the "every other" progn!!
       (setq ang (angle '(0 0 0) (vlax-curve-getFirstDeriv a (vlax-curve-getParamAtPoint a p)) ; end 1st deriv
              ); end angle & ang ;; ang and angle integrated into LM's code
       ); end setq ;; for block rotation
                            ); end foreach
); end if zerop
      ); end progn
                   ) ; end if vlax method
;;  Arguments:                                                ;;
              l (cdddr l)
    (reverse r)
;; ssget  -  Lee Mac
;; Arguments:
    (princ msg)
    (setvar 'nomutt 1)
    (setvar 'nomutt 0)
(defun LM:acdoc nil
    (LM:acdoc)
« Reply #3 on: December 15, 2014, 04:29:23 PM »
You're welcome.
Be aware that the tog var end state will affect the next item in the LOOP in that it may or may not be set to 1.
