Author Topic: French error  (Read 1552 times)
French error
« on: December 12, 2014, 05:07:56 AM »
Can anyone add the French translations for the error messages and confirm what I have please.
  1.
  2.       ((member (strcase msg t)
  3.                '("console break" "function cancelled" "quit / exit abort"
  4.                  "somethingFrench"                "fonction annulée" "quitter / sortir abandon")
  5.
  6.        )
  7.        (princ "\nFunction Cancelled.") ; <**************
  8.       )
  9.
  10.
  11.
Thanks ..
Marc'Antonio Alessi
  • Marco
Re: French error
« Reply #1 on: December 12, 2014, 11:59:03 AM »
Only italian here:
"Function cancelled"                                 "console break"            "quit / exit abort"
"Funzione annullata" "la funzione è stata annullata" "interruzione da tastiera" "esci / continua"
ymg
Re: French error
« Reply #2 on: December 12, 2014, 01:09:26 PM »
Kerry,
Your translation  is correct.
ymg
Re: French error
« Reply #3 on: December 12, 2014, 02:34:37 PM »
Still missing
"console break"
ymg
Re: French error
« Reply #4 on: December 15, 2014, 09:07:17 AM »
Kerry,
"Interruption Console" would be a possibility.
ymg
