Author Topic: Part of code to make XREF path full instead of relative  (Read 2537 times)
HasanCAD
« on: December 11, 2014, 06:26:14 AM »
There is 2 point about this part of code
- When finish the path comes as small letters I want It capital, I used strcase but not working I think that the issue in vla-put-path
- Any comments will be appreciated
  1. (defun selx (/ blk name xrefs)                              ;LEE-mac.com
  2.    (while (setq blk (tblnext "BLOCK" (not blk)))
  3.       (if (> (logand 4 (cdr (assoc 70 blk))) 0)
  4.          (progn
  5.             (setq name  (cdr (assoc 2 blk))
  6.                   xrefs (if xrefs
  7.                            (strcat xrefs "," name)
  8.                            name
  9.                         )
  10.             )
  11.          )
  12.       )
  13.    )
  14.    (ssget "X" (list '(0 . "INSERT") (cons 2 xrefs)))
  15. )
  16. (setq cntX 0)
  17.
  18. (if (sslength (setq ssBlk (selx)))
  19.    (progn
  20.       (while
  21.          (setq blk (ssname ssBlk cntX))
  22.            (setq blk (vlax-ename->vla-object blk))
  23.            (setq blkPth (vla-get-path blk))
  24.            (setq blknm (vla-get-name blk))
  25.            (if (= (vl-string-elt blkPth 0) 46)
  26.               (command "_.-xref" "_pathType" blknm "full")
  27.            )
  28.            (setq blkPth (strcase (vla-get-path blk)))
  29.            (vla-put-path blk blkPth)
  30.            (vla-update blk)
  31.            (setq cntX (1+ cntX))
  32.       )
  33.    )
  34. )
  35.
edit kdub-> formatting to code=cadlisp-7
fix title spelling
« Last Edit: December 11, 2014, 06:59:18 AM by Kerry »
Re: Part of code to make XREF path full instead of relative
« Reply #1 on: December 11, 2014, 06:58:34 AM »
Can you try again to explain your problem.
ie
I expect this : < example>
I get this : < example >
From a quick perusal, the code should work without fault.
« Reply #2 on: December 11, 2014, 07:13:05 AM »
Just for my Curiosity ..
Why Do you want the Saved Path to be in uppercase instead of the case returned by (findfile ... )
Regards
HasanCAD
« Reply #3 on: December 11, 2014, 07:30:49 AM »
fix title spelling
- Thanks kdub I believe that it is better than before
- see my sign  :oops:
ie
- The code working without fault, and I asking for comments
- I tried again and working well.  :-o  :embarrassed:
And faced another issue, I want to replace a part of path with another part
Full path
\\10.120.200.11\projects\GEN\3120B01\BASE\Col-Grids&SE\3120B01-XCOFO.dwgI want to replace
\\10.120.200.11\projects\with
X:\
HasanCAD
« Reply #4 on: December 11, 2014, 07:46:39 AM »
Regards
Some of our projects are prototype, Means the same building repeated in more than one site. And capital and small letters confusing me while change the path using Reference manager. So I want all letters case are capital.
For example
This is BASE path
Code - Text: [Select]
  1. X:\GEN\3120\PROTOTYPE\BASE\3120B01-XCOFO.dwg
This is BASE path
  1. X:\GEN\3120\PROTOTYPE\1111\3120B01-C-S101.dwg
  2. X:\GEN\3120\PROTOTYPE\2222\3120B01-C-S101.dwg
  3. X:\GEN\3120\PROTOTYPE\3333\3120B01-C-S101.dwg
« Reply #5 on: December 11, 2014, 08:22:48 AM »
Give this a try:
  1. (defun _changexrefpath (/ i newpath p xrpath)
  2.   (setq p "\\\\10.120.200.11\\PROJECTS\\")
  3.   (setq i (strlen p))
  4.     (if (and (minusp (vlax-get x 'isxref))
  5.              (setq xrpath (strcase (vlax-get x 'path)))
  6.              (vl-string-search p xrpath)
  7.              (setq newpath (strcat "X:\\" (substr xrpath i)))
  8.              (findfile newpath)
  9.         )
  10.       (vl-catch-all-error-p (vl-catch-all-apply 'vla-put-path (list x newpath)))
  11.     )
  12.   )
  13.   (princ)
  14. )
*Found Typo
« Last Edit: December 11, 2014, 08:34:19 AM by ronjonp »
HasanCAD
« Reply #6 on: December 11, 2014, 08:48:59 AM »
Give this a try:
  9.         )
  11.     )
  12.   )
  13.   (princ)
  14. )
*Found Typo
Gives error
_CHANGEXREFPATH
_$
; error: bad argument type: (or stringp symbolp): nil
_$
By the way I changed G:\\ to X:\\
« Reply #7 on: December 11, 2014, 09:12:25 AM »
Untested :
  1.
  2. (defun _changexrefpath (/ newpath path1 xrpath old new)
  3.    (setq new "G:\\")
  4.    (setq old "//10.120.200.11\\PROJECTS\\")
  5.    (vlax-for x
  6.              )
  7.       (if (minusp (vlax-get x 'isxref))
  8.          (if (and (setq xrpath (strcase (vlax-get x 'path)))
  9.                   (vl-string-search old xrpath)
  10.                   (setq newpath (vl-string-subst
  11.                                    new
  12.                                    old
  13.                                    xrpath
  14.                                 )
  15.                   )
  16.                   (findfile newpath)
  17.              )
  18.             (vl-catch-all-error-p
  19.                (vl-catch-all-apply 'vla-put-path (list x newpath))
  20.             )
  21.          )
  22.       )
  23.    )
  24.    (princ)
  25. )
  26.
  27. ;; (_changexrefpath)
  28.
  29.
added:
just an option now that ronjonp's typo is fixed :)
« Last Edit: December 11, 2014, 09:16:30 AM by Kerry »
