Unfortunately Thunderbird is a system agnostic program (i.e. it runs on Linux, Unix, OSX, Windows, etc.). And out of those only Windows has any ActiveX stuff. So they didn't add an ActiveX connector for TB.However, you could send the mail via a command-line. See the help on composing a message via command line options: http://kb.mozillazine.org/Command_line_arguments_(Thunderbird)That you should be able to do from AutoLisp through the startapp function.
Thanks irneb. The page that you referred to contains no contents.
MeasureUp, add a ) to the end of the link irneb gave you, as it is shown but the link created omitted that paren.
