Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
Vertically Challenged
Land Lubber / Geographically Positioned
Topic:
X-ref Slowing down drawing.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: X-ref Slowing down drawing. (Read 2732 times)
DPATTERSON
Guest
on:
December 10, 2014, 03:33:37 PM »
I have this problem a lot, but I often work with pdf xref drawing and i am working with one that slows down my CAD so much that its impossible to work with any tips?
Thank you in Advance!!!!!
-David
Logged
Seagull
Every Student their own Lesson
WWW
Re: X-ref Slowing down drawing.
Reply #1 on:
December 10, 2014, 04:20:13 PM »
how are you attaching it?
IF
using MAP there is a setting to reserve memory for images
not sure if it has any impact on A)PDF's or B)PDF, as XREF
Logged
Seagull
WWW
Reply #2 on:
December 10, 2014, 05:30:45 PM »
also check all files for excess annotative scales, audit, and purge as you see fit
further see shat setting you have for XLOADCTL? suggest setting of 3 might help
Logged
ChrisCarlson
Guest
Reply #3 on:
December 11, 2014, 04:28:51 PM »
PDF's are notoriously cumbersome within CAD, especially with vector PDF's.
Suggested fix has always been to convert to DWF or TIFF (if you dont mind losing the snappy points)
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
Topic:
