Author Topic: Navisworks - Sectioned modeled renders ENTIRE model  (Read 8255 times)
Matt__W
  • I like my water diluted.
« on: December 10, 2014, 01:56:41 PM »
I have a model that is sectioned to show a cut through a mechanical room and when I render the current view in the cloud using my A360 account, I get the entire building rendered as if it weren't sectioned. Is this "by design", a flaw or is there a setting somewhere that I'm missing??
Autodesk Expert Elite
Re: Navisworks - Sectioned modeled renders ENTIRE model
« Reply #1 on: December 10, 2014, 02:05:06 PM »
Most likely a bug
Matt__W
« Reply #3 on: December 10, 2014, 03:26:24 PM »
GAHH!!  That sucks!
« Reply #4 on: December 10, 2014, 03:29:32 PM »
GAHH!!  That sucks!
Yet another reason I detest the subscription model, and the SUITE-ing of products
into a bundle of software that doesn't even all work well together, let alone as a stand alone (or with added 'cloud' features)solution.
dgorsman
« Reply #5 on: December 10, 2014, 06:41:24 PM »
GAHH!!  That sucks!
Which has ZERO to do with the problem at hand.   :uglystupid2:
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Matt__W
« Reply #6 on: December 10, 2014, 09:18:09 PM »
After a while you get used to it.
« Reply #7 on: December 11, 2014, 08:39:52 AM »
GAHH!!  That sucks!
Actually it is the root cause of the problem at hand.
