Author Topic: Point is Inside polyline (Now with Bulges)  (Read 22854 times)
ymg
Re: Point is Inside polyline
« Reply #30 on: April 25, 2015, 11:53:21 AM »
Lee,
For polylines with bulge, it gets messy.
You can approximate the curve part by adding straight segments.
(defun approxpoly (en / px fe)
      (setq px (* 0.75 (acet-geom-pixel-unit))
            fe (acet-list-remove-adjacent-dups
  (acet-geom-object-point-list en (/ px 2.0)))
But this is bound to create problems when you are on the
boundary.
ymg
GP
  • Vercelli, Italy
« Reply #31 on: April 25, 2015, 01:58:20 PM »
I don't think this will work with self intersecting polylines.
Also what happen If point P is directly on a vertex of the polyline?
What about polylines with arc segments?
True...  but I think also the other codes posted  :-)
This code should works with self intersecting polylines and also If point P is directly on a vertex/segment of the polyline:
  1. (defun inside_p (:p :Lst / far_p cross on)
  2.     (setq far_p (mapcar '+ '(1.0 1.0 0.0) (getvar "extmax")))
  3.     (setq cross 0)
  4.     (if (not (member :p :Lst))
  5.         (mapcar
  6.             '(lambda (a b)
  7.                  (if (inters :p far_p a b) (setq cross (1+ cross)))
  8.                  (if (equal (+ (distance :p a) (distance :p b)) (distance a b) 1e-8) (setq on t))
  9.              )
  10.             :Lst (cdr :Lst)
  11.         )
  12.         (setq on t)
  13.     )
  14.     (or (not (zerop (rem cross 2))) on)
  15. )
« Last Edit: April 25, 2015, 06:29:26 PM by GP »
ymg
« Reply #32 on: April 25, 2015, 05:03:35 PM »
Gian Paolo,
The winding number method works with self-intersecting polylines
and also if your point is on a vertex.
It does not work with bulges though!
ymg
Benchmarking .............Elapsed milliseconds / relative speed for 1024 iteration(s):
    (PTINPOLY_P1 P L)..........1279 / 1.52 <fastest>
    (INSIDE_P P L).............1934 / 1.01
    (VK_ISPOINTINSIDE P L).....1950 / 1.00 <slowest>
Images below from:  http://geomalgorithms.com/a03-_inclusion.html
« Last Edit: April 25, 2015, 05:58:59 PM by ymg »
GP
  • Vercelli, Italy
« Reply #33 on: April 25, 2015, 07:15:57 PM »
Thank you ymg, I realized now, but... seems it does not work always.
roy_043
  • BricsCAD 18
« Reply #34 on: April 26, 2015, 10:00:43 AM »
@ GP:
Further, one must decide whether a point on the polygon's boundary is inside or outside. A standard convention is to say that a point on a left or bottom edge is inside, and a point on a right or top edge is outside. This way, if two distinct polygons share a common boundary segment, then a point on that segment will be in one polygon or the other, but not both at the same time. This avoids a number of problems that might occur, especially in computer graphics displays.
ymg
« Reply #35 on: April 26, 2015, 10:02:54 AM »
Gian Paolo,
Yes there seems to be some inconsistencies when we are directly
on the line.
Maybe due to some rounding error in the onleft routine.
Thanks,
ymg
(defun PtInPoly_p1 (p l / i l p1 p2 v wn y)
   ;; Returns t if point p is strictly to the left of v1->v2   by ymg         ;
   (defun isleft (p v1 v2 / xp yp)
       (setq  xp (car  p)  yp (cadr  p))
       (minusp (- (* (- (cadr v1) yp) (- (car v2) xp)) (* (- (car v1) xp) (- (cadr v2) yp))))
   ;; Initialize the loop.                                                    ;
   (setq p1 (car  l)
  y (cadr p)
         wn 0
   ;; Loop through all edges of polygon.                                      ;
   (foreach p2 (cdr l)
      (if (<= (cadr p1) y)
(if (> (cadr p2) y)
    (if (isleft p p1 p2) (setq wn (1+ wn)))
         (if (<= (cadr p2) y)
    (if (not (isleft p p1 p2)) (setq wn (1- wn)))
      (setq p1 p2)
   (not (zerop wn));; Returns t if wn not equal to zero.                      ;
 ;   // loop through all edges of the polygon
 ;   for (int i=0; i<n; i++) {   // edge from V[i] to  V[i+1]
 ;       if (V[i].y <= P.y) {          // start y <= P.y
 ;          if (V[i+1].y  > P.y)      // an upward crossing
 ;               if (isLeft( V[i], V[i+1], P) > 0)  // P left of  edge
 ;                    ++wn;            // have  a valid up intersect
 ;       else {                        // start y > P.y (no test needed)
 ;           if (V[i+1].y  <= P.y)     // a downward crossing
 ;                if (isLeft( V[i], V[i+1], P) < 0)  // P right of  edge
 ;                    --wn;            // have  a valid down intersect
 ;   return wn;
(defun listpol (en / i p l)
  (setq i (if (vlax-curve-IsClosed en)
       (vlax-curve-getEndParam en)
     (+ (vlax-curve-getEndParam en) 1)
  (while (setq p (vlax-curve-getPointAtParam en (setq i (1- i))))
      (setq l (cons (trans p 0 1 ) l))
(defun c:test (/ en l p)
   (princ "\nSelect Polyline Under Test: ")
   (setq en (car (entsel))
  l (listpol en)
  l (cons (last l) l)
   (setvar 'PDSIZE -1.5)
   (while (setq p (getpoint "\nPick a Point: "))
      (if (ptinpoly_p1 p l)
         (entmakex (list (cons 0 "POINT") (cons 10 p) (cons 62 1)))
(entmakex (list (cons 0 "POINT") (cons 10 p) (cons 62 7)))
« Last Edit: April 26, 2015, 10:15:22 AM by ymg »
ymg
« Reply #36 on: April 26, 2015, 03:14:46 PM »
Roy,
Here I've modified on left by removing the minusp test,
and modified ptinpoly_p to test exactly like Sunday's
routine.
Works more or less OK as by his description.
I do run into some roundoff error on the left side
of the test poly.
(defun PtInPoly_p5 (p l / i l p1 p2 v wn y)
   (setq p1 (car  l)
  y (cadr p)
         wn 0
   (foreach p2 (cdr l)
(if (> (cadr p2) y)
    (if (> (isleft p p1 p2) 0) (setq wn (1+ wn)))
    (if (< (isleft p p1 p2) 0) (setq wn (1- wn)))
      (setq p1 p2)
roy_043
  • BricsCAD 18
« Reply #37 on: April 27, 2015, 09:23:57 AM »
@ ymg:
I was trying to replicate your experiment and while doing so came across some strange results:
(setq ptLst '((0.0 0.0 0.0) (104.0 0.0 0.0) (104.0 72.0 0.0) (0.0 72.0 0.0)))
(GEO_GEOM_POINTINSIDEPOINTLIST_P '(1.0 1.0 0.0) ptLst) => T
(PtInPoly_p1                     '(1.0 1.0 0.0) ptLst) => T
(PtInPoly_p2                     '(1.0 1.0 0.0) ptLst) => T
(PtInPoly_p3                     '(1.0 1.0 0.0) ptLst) => T
(PtInPoly_p5                     '(1.0 1.0 0.0) ptLst) => nil
(GEO_GEOM_POINTINSIDEPOINTLIST_P '(-1.0 0.0 0.0) ptLst) => nil
(PtInPoly_p1                     '(-1.0 0.0 0.0) ptLst) => T
(PtInPoly_p2                     '(-1.0 0.0 0.0) ptLst) => T
(PtInPoly_p3                     '(-1.0 0.0 0.0) ptLst) => T
(PtInPoly_p5                     '(-1.0 0.0 0.0) ptLst) => nil
roy_043
  • BricsCAD 18
« Reply #38 on: April 27, 2015, 09:40:30 AM »
It is interesting to note that where http://geomalgorithms.com/a03-_inclusion.html mentions that, by convention, points on the left and bottom edges are considered inside the polyline, ymg's code favors the right and bottom edges instead and the code I have 'ported' favors the left and top edges.
ymg
« Reply #39 on: April 27, 2015, 11:13:27 AM »
Roy,
This is a finicky! beast.
It is somewhat unsastisfying for example that a point of the polyline
would be considered outside.
ymg
roy_043
  • BricsCAD 18
« Reply #40 on: April 28, 2015, 05:39:36 AM »
@ ymg:
I now see that your code requires a different point list than mine. For your code the last point in the list must be equal to the first point. The strange results reported in post #37 are all due to this oversight. My apologies for that.
The same test with correct point lists:
(setq ptLstAlt '((0.0 0.0 0.0) (104.0 0.0 0.0) (104.0 72.0 0.0) (0.0 72.0 0.0) (0.0 0.0 0.0)))
(PtInPoly_p1                     '(1.0 1.0 0.0) ptLstAlt) => T
(PtInPoly_p2                     '(1.0 1.0 0.0) ptLstAlt) => T
(PtInPoly_p3                     '(1.0 1.0 0.0) ptLstAlt) => T
(PtInPoly_p5                     '(1.0 1.0 0.0) ptLstAlt) => T
(vk_IsPointInside                '(1.0 1.0 0.0) ptLstAlt) => T
(PtInPoly_p1                     '(-1.0 0.0 0.0) ptLstAlt) => nil
(PtInPoly_p2                     '(-1.0 0.0 0.0) ptLstAlt) => nil
(PtInPoly_p3                     '(-1.0 0.0 0.0) ptLstAlt) => nil
(PtInPoly_p5                     '(-1.0 0.0 0.0) ptLstAlt) => nil
(vk_IsPointInside                '(-1.0 0.0 0.0) ptLstAlt) => nil
ymg
« Reply #41 on: April 28, 2015, 08:44:32 AM »
Roy,
No apologies necessary,
I attach a lot of value to your Input.
ymg
ymg
Re: Point is Inside polyline (Now with Bulges)
« Reply #42 on: April 29, 2015, 09:50:59 AM »
Here I've modified approxpoly to work with a tolerance
instead of the zoom level of your screen.
If we use it to get the point list of a polyline with bulges,
ptinpoly_p returns valid results to within the tolerance
given above.
I attached a test program and a drawings with the
polylines I used for testing.
Would appreciate to know if approxpoly can be ported
to briscad.
ymg
  1. ;; Routine to Test if a Point is inside a polylines                           ;
  2. ;; Will work with bulges and Self-Crossing and Overlapping Poly                ;
  3. ;;        ;
  4.
  5. (defun c:test (/ *AcadDoc* *error* en l p varl listpol approxpoly ptinpoly_p)
  6.     ;;; Error Handler by ElpanovEvgenyi                                       ;
  7.     (defun *error* (msg)
  8.         (mapcar 'eval varl)
  9.         (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")))
  10.            (princ (strcat "\nError: " msg))
  11.         )
  12.         (and *AcadDoc* (vla-endundomark *AcadDoc*))
  13.         (princ)
  14.     )
  15.
  16.     (setq varl '("CLAYER" "OSMODE" "CMDECHO" "PDMODE" "PDSIZE")
  17.           varl (mapcar (function (lambda (a) (list 'setvar a (getvar a)))) varl)
  18.     )
  19.
  20.    (or *AcadDoc* (setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
  21.
  22.    ;;        ;
  23.    ;; listpol     by ymg    (Simplified a Routine by Gile Chanteau)           ;
  24.    ;;        ;
  25.    ;; Parameter:  en,  Entity Name or Object Name of Any Type of Polyline     ;
  26.    ;;        ;
  27.    ;; Returns:    List of Points in Current UCS                               ;
  28.    ;;        ;
  29.    ;; Notes:      On Closed Polyline the Last Vertex is Same as First)        ;
  30.    ;;        ;
  31.
  32.    (defun listpol (en / i l)
  33.       (repeat (setq i (fix (1+ (vlax-curve-getEndParam en))))
  34.          (setq l (cons (trans (vlax-curve-getPointAtParam en (setq i (1- i))) 0 1) l))
  35.       )
  36.    )
  37.
  38.    ;;        ;
  39.    ;; approxpoly        by ymg       (Derived from Fast Select)               ;
  40.    ;;        ;
  41.    ;; Parameters: en   Entity Name of a Polyline (Any types)                  ;
  42.    ;;             tol  Tolerance Allowed for Lines Segments.                  ;
  43.    ;;        ;
  44.    ;; Returns:   A List of Points Replacing Bulges With Straight Segments.    ;
  45.    ;;        ;
  46.
  47.    (defun approxpoly (en tol)
  48.       (acet-list-remove-adjacent-dups
  49.            (acet-geom-object-point-list en tol)
  50.       )
  51.    )
  52.
  53.    ;;=========================================================================;
  54.    ;;        ;
  55.    ;;      PtInPoly_p(): Winding number test for a point in a polygon         ;
  56.    ;;        ;
  57.    ;;      Input:    p = a point                                              ;
  58.    ;;               en = ename or vla-object of a closed polyline.            ;
  59.    ;;        ;
  60.    ;;      Return:  t, if point is in polyline. (wn is not 0)                 ;
  61.    ;;        ;
  62.    ;; Original code in C++ by Dan Sunday, Translated by ymg                   ;
  63.    ;; See: http://geomalgorithms.com/a03-_inclusion.html                      ;
  64.    ;;=========================================================================;
  65.
  66.    (defun ptinpoly_p (p l / i p1 p2 v wn y isleft)
  67.
  68.       ;; Returns t if point p is strictly to the left of v1->v2   by ymg      ;
  69.       (defun isleft (p v1 v2 / xp yp)
  70.           (setq  xp (car  p)  yp (cadr  p))
  71.           (- (* (- (cadr v1) yp) (- (car v2) xp)) (* (- (car v1) xp) (- (cadr v2) yp)))
  72.       )
  73.
  74.       ;; Initialize the loop.                                                 ;
  75.       (setq p1 (car  l)
  76.              y (cadr p)
  77.             wn 0
  78.       )
  79.
  80.       ;; Loop through all edges of polygon.                                   ;
  81.       (foreach p2 (cdr l)
  82.          (if (<= (cadr p1) y)
  83.             (if (> (cadr p2) y)
  84.                (if (> (isleft p p1 p2) 0) (setq wn (1+ wn)))
  85.             )
  86.             (if (<= (cadr p2) y)
  87.                (if (< (isleft p p1 p2) 0) (setq wn (1- wn)))
  88.             )
  89.          )
  90.          (setq p1 p2)
  91.       )
  92.       (not (zerop wn)) ;; Returns t if wn not equal to zero.                  ;
  93.    )
  94.
  95.
  96.    (princ "\nSelect Polyline Under Test: ")
  97.    (setq en (car (entsel))
  98.          ;l (listpol en)           ;   Use this if poly has no bulges         ;
  99.           l (approxpoly en 0.001)  ;   Use this if poly has bulges.           ;
  100.    )
  101.
  102.    (setvar 'PDMODE 34) (setvar 'PDSIZE -3.5)
  103.    (while (setq p (getpoint "\nPick a Point: "))
  104.       (if (ptinpoly_p p l)
  105.          (entmakex (list (cons 0 "POINT") (cons 10 p) (cons 62 1)))
  106.          (entmakex (list (cons 0 "POINT") (cons 10 p) (cons 62 7)))
  107.       )
  108.    )
  109.    (*error* nil)
  110. )
  111.
« Last Edit: April 29, 2015, 10:01:51 AM by ymg »
« Reply #43 on: April 29, 2015, 10:30:33 AM »
THIS could be used to trace the polyline rather than relying on ET functions.
Here is a quick test with your code above.
ymg
« Reply #44 on: April 29, 2015, 10:39:11 AM »
Ronjomp,
Looks good!! to me.
I'll do some test to see what happen when
there is no or little bulges.
ymg
