Author Topic: I want lisp to get Elevation label at the polyline starting edge and ending edge  (Read 3763 times)
sanju2323
I want lisp to get at the beginning and end of each polyline of the Elevation Label.
ChrisCarlson
Ok, simply contact
http://www.lee-mac.com/contact.html
or
https://www.blackboxcad.com/Contact.html
and I'm sure they will write this for you, for a nominal fee
Chris,
There are quite a few people here who pay the bills by doing this stuff into the wee hours of the morning.
ChrisCarlson
Well those are the only two I know maybe a master list should be created.
tedg
Chris,
Good point, maybe someone here who does programming into the wee hours for a nominal fee will respond.  ;)
This post looks familiar
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
Rob...
CAD Tech
snownut2
  • Bricscad 22 Ultimate
Well he's consistent & persistent if nothing else....
sanju2323,
If I ask you for a more refined description of what you expect from the program could you provide it ?
added:
Opening an AutoCAD 2000 format file.
Regenerating model.
AutoCAD menu utilities loaded.
Command:
Autodesk DWG.  This file is a TrustedDWG last saved by an Autodesk application or Autodesk licensed application.
Will this be consistent ?
The Text SEEMS to have it's insertion point coincident with the Polyline end/start vertex.
Do you expect to have the data evaluated in any specific sequence ?
How do you want the resulting date presented. ?
« Last Edit: December 11, 2014, 07:09:36 PM by Kerry »
sanju2323
Just like that
  1. (defun C:qq ()
  2.   (setq ss (ssget '((0 . "LWPOLYLINE"))))
  3.   (setq sslngth (sslength ss))
  4.   (setq idx 0)
  5.   (repeat sslngth
  6.     (setq ename (ssname ss (setq sslngth (1- sslngth))))
  7.     (setq edata (entget ename))
  8.     (setq xy (cdr (assoc 38 edata)))
  9.     (setq xy1 (cdr (assoc 10 edata)))
  10.     (setq xx (rtos xy 2 3))
  11.     (command "text" xy1 2 30 xx "")
  12.   )
  13. )
  14.
edit:kdub-> code formatted and codeTags added code=cadlisp-7
« Last Edit: December 11, 2014, 07:52:42 PM by Kerry »
Just like that
OK, so you wanted to PUT the text , not GET it.
Happy that you have resolved your problem
