Author Topic: read-line issue ? or variable setting ?  (Read 1830 times)
Andrea
« on: December 09, 2014, 12:25:57 PM »
Hi all,..
anyone can run READ-LINE on this file ???
(setq file (open "C:\\test\\test2.txt" "r"))
(setq rline (read-line file))
(close file)
it return..
"˙ŝt\000e\000s\000t\000f\000i\000l\000e\000"
Keep smile...
Re: read-line issue ? or variable setting ?
« Reply #1 on: December 09, 2014, 12:30:23 PM »
Same here. This is probably the culprit.
« Last Edit: December 09, 2014, 12:34:17 PM by ronjonp »
Andrea
« Reply #2 on: December 09, 2014, 12:33:33 PM »
I check the file propreties...all seem ok..
strange thing... :|
Keep smile...
Andrea
« Reply #3 on: December 09, 2014, 12:50:46 PM »
Bingo !  thank you very much Ron !
Now I've to figureout how to change this proprety...
thanks again. :)
Keep smile...
Andrea
« Reply #4 on: December 09, 2014, 01:25:11 PM »
there...
(defun ReadasUnicode (file / fsobj readalldoc)
  (if (findfile file)
      (setq fsobj (vlax-create-object "Scripting.FileSystemObject"))
      (setq file (vlax-invoke-method fsobj 'OpenTextFile file 1 :vlax-false -2))
      (setq readalldoc (vlax-invoke file 'readall))
      (vlax-invoke file 'close)
      (vlax-release-object fsobj)
      (vlax-release-object file)
  readalldoc
any other suggestion ?
« Last Edit: December 09, 2014, 01:49:29 PM by Andrea »
Keep smile...
roy_043
  • BricsCAD 18
« Reply #5 on: December 10, 2014, 05:37:51 AM »
Since you are also working with BricsCAD this may be of interest:
(defun BinReadUnInt16 (fileName / fptr int ret)
  (setq fptr (open fileName "rb"))
  (while (setq int (vle-read-uint16  fptr))
    (setq ret (cons int ret))
  (close fptr)
  (reverse ret)
(BinReadUnInt16 "C:/downloads/test2.txt") => (65279 116 101 115 116 102 105 108 101 13 10)
(vl-list->string (BinReadUnInt16 "C:/downloads/test2.txt")) => "˙testfile\r\n"
BTW:
According to the BricsCAD 'Lisp Developer Support Package' AutoLisp also supports (open <filename> "rb") and (open <filename> "wb"). Where "rb" stands for "read binary" and "wb" for "write binary".
VovKa
  • Ukraine
« Reply #6 on: December 10, 2014, 07:02:00 AM »
http://www.theswamp.org/index.php?topic=39617.msg449060#msg449060
(vk_ReadTextStream "C:\\test\\test2.txt" "utf-16")
« Reply #7 on: December 10, 2014, 08:51:16 AM »
This might also be of some interest:
http://www.theswamp.org/index.php?topic=39814.0
