Author Topic: Access all entities within a Block Reference  (Read 2147 times)
mailmaverick
« on: December 08, 2014, 06:38:03 AM »
How to Access all entities within a Block Reference.
Please note that I don't want to access all entities within a Block Definition but Block Reference.
roy_043
  • BricsCAD 18
Re: Access all entities within a Block Reference
« Reply #1 on: December 08, 2014, 07:46:50 AM »
A block reference does not contain entities. It is merely a reference to a block definition that contains entities. Maybe you should explain what you want to accomplish.
« Reply #2 on: December 08, 2014, 12:19:13 PM »
Here is a brief explanation I posted a while back which may clarify things for you.
mailmaverick
« Reply #3 on: December 08, 2014, 12:53:08 PM »
I want to get bounding box of some of the entities (not all) in the block reference.
Also, I do not want bounding box of the entire block.
I have found certain LISP routines on the internet to get list of entities in a block, it gives me list of original entities in the block definition. When I take bounding box of these entities, I see that the coordinates point to the original block definition and not the selected block reference. However, I need coordinates of the entities with respect to the selected block reference.
How to accomplish that ?
gile
  • Marseille, France
« Reply #4 on: December 08, 2014, 01:14:07 PM »
You can 'vla-Explode' the block reference, 'vla-GetBoundingBox' the returned entities and 'vla-Delete' them.
« Last Edit: December 08, 2014, 01:17:12 PM by gile »
dgorsman
« Reply #5 on: December 08, 2014, 01:41:30 PM »
Like the block instance is the similar to the definition modified for instance scale and rotation, any boundary coordinates can be applied to each instance using the same transform process.  Calculate the boundary once then modify it using the properties of each needed instance.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
mailmaverick
« Reply #6 on: December 08, 2014, 07:53:28 PM »
Can you please post some code for this.
irneb
« Reply #7 on: December 09, 2014, 06:00:57 AM »
It seems to me what you're after is a "translate" function to convert the internal coordinates of a block to the external coordinates of one of its references. If so here's an old thread where Lee helped me out: http://www.cadtutor.net/forum/showthread.php?57392-Transforming-Points-in-mirrored-blocks
« Reply #8 on: December 09, 2014, 02:46:58 PM »
You could also refer to my LM:blockboundingbox function included in my Automatic Block Break program.
