Author Topic: importing a layout from a other template  (Read 1908 times)
sybold
« on: December 03, 2014, 09:46:14 AM »
I have 2 templates, one for Meters and one for millimeters
When imporing a layout from a library template file, on the millimeter templatefile the blocks on the layout will have blockscale milimeters, all good
When imporing a layout from a library template file, on the Meter templatefile the blocks on the layout will have blockscale unitless, how and why does this happen.
the blocks on the library template file, blockscale are set to milimeters.
using this macro i'm importing the layout
^C^C-layout;template;"layouts.dwg";"A0";-layout;d;empty;tilemode;0;
« Last Edit: December 03, 2014, 10:03:37 AM by sybold »
Re: importing a layout from a other template
« Reply #1 on: December 03, 2014, 09:49:45 AM »
different settings under UNITS
and under OPTIONS>>User Preferences>>Insertion Scale
sybold
« Reply #2 on: December 03, 2014, 09:54:43 AM »
those are set correctly, the strange thing is, they won't scale, they are just beinging imported and the blockscale gets changed to unitless
« Reply #3 on: December 03, 2014, 10:03:00 AM »
sounds like there is an issue in the original block definitions then
sybold
« Reply #4 on: December 03, 2014, 10:12:33 AM »
i'm confused at the moment
« Reply #5 on: December 03, 2014, 10:20:30 AM »
is that the SAME block being inserted TWICE?
IF yes....possible that you are redefining the original, or not during the insertion process.
sybold
« Reply #6 on: December 03, 2014, 12:58:16 PM »
no it's not being redefined.
« Reply #7 on: December 03, 2014, 01:13:23 PM »
please attach copies of the file(s) containing the layouts in question, and the one you are attempting to import them into for further examination
