Author Topic: Test if LwPoly Is Closed also apparently  (Read 2392 times)
Marc'Antonio Alessi
  • Marco
« on: November 26, 2014, 09:59:28 AM »
Is this a valid test?
(defun c:LwPolyIsClosed ( / EntNam EntObj)
  (or
    (eq
      :vlax-true
      (vla-get-closed (setq EntObj (vlax-ename->vla-object (setq EntNam (car (entsel))))))
  ; (= 1 (logand 1 (cdr (assoc 70 (entget EntNam)))))
    (equal (vlax-curve-getStartPoint EntObj)  (vlax-curve-getEndPoint EntObj))
Tharwat
  • Hypersensitive
Re: Test if LwPoly Is Closed also apparently
« Reply #1 on: November 26, 2014, 11:06:35 AM »
My attempt .
  1. (defun c:ClosedPoly-p (/ s)
  2.   (princ "\n Select LWpolyline ..")
  3.   (and (setq s (ssget "_+.:S:E" '((0 . "LWPOLYLINE"))))
  4.        (vlax-curve-isclosed (ssname s 0))
  5.   )
  6. )
  7.
Marc'Antonio Alessi
  • Marco
« Reply #2 on: November 26, 2014, 11:18:57 AM »
My attempt .
  5.   )
  6. )
  7.
...but "also apparently" > perimeter is closed manually (flag 70 = 0)...
« Reply #3 on: November 26, 2014, 12:02:35 PM »
Marc'Antonio, I use essentially what you have posted except I use the optional fuzz factor for the (equal) comparison. Using a fuzz of 0.0001 helps to eliminate any errors due to computer rounding issues.
Marc'Antonio Alessi
  • Marco
« Reply #4 on: November 26, 2014, 12:30:27 PM »
Ok, so vlax-curve-isclosed is not always valid.
Thanks.
Andrea
« Reply #5 on: December 05, 2014, 01:11:44 PM »
(defun closedPoly (entname / entdata res)
    ((eq (type entname) 'ENAME) (setq entdata (entget entname)))
    ((eq (type entname) 'VLA-OBJECT) (setq entdata (entget (vlax-vla-object->ename entname))))
  (if entdata
      (eq 1 (cdr (assoc 70 entdata)))
      (setq res 1)
      (eq (vl-princ-to-string (assoc 10 entdata))
                   (vl-princ-to-string (assoc 10 (reverse entdata)))
   (setq res 3)
(setq res 2)
  res
  ;(closedPoly (car (entsel)))
1 = Closed
2 = not closed
3 = not closed but the last point correspond to the first point
Keep smile...
Marc'Antonio Alessi
  • Marco
« Reply #6 on: December 06, 2014, 05:17:45 AM »
Why not: (equal (assoc 10 entdata) (assoc 10 (reverse entdata)) [fuzz])  ?
