Author Topic: Comparing List of Points  (Read 7328 times)
Patrick_35
Re: Comparing List of Points
« Reply #15 on: November 27, 2014, 05:49:48 AM »
Hi
To compare two list without vl-every
(equal lst-1 lst-2 1e-4) --> T
(equal lst-1 lst-2 1e-5) --> nil
This only seems to work if the order is identical.
Yes, the goal is to see if the two lists are identical
Now, if the order does not matter, we can do
(equal (vl-sort lst-1 '<) (vl-sort lst-2 '<) 1e-4)
« Reply #16 on: November 27, 2014, 12:13:05 PM »
Be careful with vl-sort:
_$ (setq lst-1 '(1 2 3 4 4 5) lst-2 '(1 2 2 3 4 5))
(1 2 2 3 4 5)
_$ (equal (vl-sort lst-1 '<) (vl-sort lst-2 '<) 1e-4)
T
ribarm
  • Marko Ribar, architect
« Reply #17 on: November 27, 2014, 12:47:40 PM »
(1 2 2 3 4 5)
T
1+
Maybe...
(defun f ( lst-1 lst-2 )
  (if (and (listp (car lst-1)) (listp (car lst-2)))
    (equal
      (mapcar 'nth
        (vl-sort-i lst-1 '(lambda ( a b ) (< (distance '(0.0 0.0 0.0) a) (distance '(0.0 0.0 0.0) b))))
        (mapcar '(lambda ( x ) lst-1) lst-1)
      (mapcar 'nth
        (vl-sort-i lst-2 '(lambda ( a b ) (< (distance '(0.0 0.0 0.0) a) (distance '(0.0 0.0 0.0) b))))
        (mapcar '(lambda ( x ) lst-2) lst-2)
      1e-4
    (equal
      (mapcar 'nth
        (vl-sort-i lst-1 '<)
      (mapcar 'nth
        (vl-sort-i lst-2 '<)
      1e-4
« Last Edit: November 27, 2014, 01:07:11 PM by ribarm »
M.R. on Youtube
roy_043
  • BricsCAD 18
« Reply #18 on: November 27, 2014, 01:23:31 PM »
I am stating the obvious here: Sorting a flat list of reals representing alternating X and Y coordinates of 2D points makes little sense.
« Reply #19 on: November 27, 2014, 02:09:05 PM »
Agreed, but then neither does comparing arbitrary X & Y values between the two lists - if I've understood what the OP is looking to achieve, I would have expected an ordered comparison up to permutation, e.g. something like:
  1. (defun compare ( a b )
  2.     (defun recurse ( a b c )
  3.         (and a (or (equal (append a c) b 1e-8) (recurse (cddr a) b (append c (list (car a) (cadr a))))))
  4.     )
  5.     (recurse a b nil)
  6. )
  1. _$ (compare '(1 2 3 4 5 6 7 8 9 0) '(5 6 7 8 9 0 1 2 3 4))
  2. T
Patrick_35
« Reply #20 on: November 27, 2014, 03:02:30 PM »
(1 2 2 3 4 5)
T
Oh yes, you are right, I had not seen that vl-sort truncates the result with integer
(vl-sort '(1 2 3 4 4 5) '<) --> (1 2 3 4 5)
(vl-sort '(1 2 2 3 4 5) '<) --> (1 2 3 4 5)
and (equal '(1 2 3 4 5) '(1 2 3 4 5)) return T
but (equal (vl-sort '(1.0 2.0 3.0 4.0 4.0 5.0) '<) (vl-sort '(1.0 2.0 2.0 3.0 4.0 5.0) '<)) work
and (equal (vl-sort '(1.0 2.0 3.0 4.0 4.0 5.0) '<) (vl-sort '(1.0 2.0 2.0 3.0 4.0 5.0) '<) 1e-4) work too
Marc'Antonio Alessi
  • Marco
« Reply #21 on: November 27, 2014, 03:50:52 PM »
Only with integers:
(vl-sort  '(3 2 1 3 1 2 2 2 1.0 1.0 1.0 1.0) '<)
(1 1.0 1.0 1.0 1.0 2 3)
(vl-sort  '("a" "A" "a") '<)
("A" "a" "a")
(vl-sort  '("a" "A" "a" "A") '<)
("A" "A" "a" "a")
roy_043
  • BricsCAD 18
« Reply #22 on: November 27, 2014, 04:38:25 PM »
Iterative approach:
  1. (defun Roy_Compare (lstA lstB / num revLstB)
  2.   (if (= (setq num (length lstA)) (length lstB))
  3.     (progn
  4.       (while
  5.         (and
  6.           (> num 0)
  7.           (not (equal lstA lstB 1e-8))
  8.         )
  9.         (setq num (- num 2))
  10.         (setq lstA (append (cddr lstA) (list (car lstA) (cadr lstA))))
  11.       )
  12.       (/= num 0)
  13.     )
  14.   )
  15. )
  1. (Roy_Compare '(1 2 3 4 5 6 7 8 9 0) '(5 6 7 8 9 0 1 2 3 4))
Of course there is still the issue of polylines that overlap but are reversed.
cmwade77
« Reply #23 on: December 01, 2014, 11:20:03 AM »
Yes,
I tried to visualise the use for comparing point lists where the point order does not matter.
.... wasn't successful.
Care to share the purpose of the test ?
Yes, I am using the boundary command to generate plines and as a result there are some instances where a duplicate polyline gets created but with a different order for the points. This causes the overkill command to fail to identify that they are identical and delete the duplicate. Basically, the polylines need to be identical, but the order that the points were drawn in do not need to be identical.
