Author Topic: Comparing List of Points  (Read 7090 times)
cmwade77
« on: November 25, 2014, 01:51:03 PM »
Ok, I have a list of points from two different polyline objects. I need to compare to see if the list points are identical, but I need to account for the fact that the order of the points may be different. Any ideas on how to accomplish this?
Tharwat
  • Hypersensitive
Re: Comparing List of Points
« Reply #1 on: November 25, 2014, 02:03:27 PM »
Try this .
lst-1 represents the first list as well the second one .
  1. (vl-every '(lambda (q p) (equal q p 1e-8)) lst-1 lst-2)
  2.
cmwade77
« Reply #2 on: November 25, 2014, 02:13:39 PM »
Perhaps I am doing something wrong, here is what I have:
(setq PtA (vlax-safearray->list (vlax-variant-value retCoordA))
PtB (vlax-safearray->list (vlax-variant-value retCoordB))
(if (vl-every '(lambda (q p) (equal q p 1e-8)) PtA PtB)
     (alert "Objects are the same")
     (alert "Objects are different")
Even when the objects are the same, it returns that they are different.
ribarm
  • Marko Ribar, architect
« Reply #3 on: November 25, 2014, 02:21:11 PM »
  1. (vl-every '(lambda ( x ) (eq x T)) (mapcar '(lambda ( x ) (vl-some '(lambda ( y ) (equal x y 1e-5)) lst-1)) lst-2))
  2.
The same as Tharwat explained lst-1 and lst-2 are point lists...
M.R. on Youtube
Tharwat
  • Hypersensitive
« Reply #4 on: November 25, 2014, 02:21:58 PM »
Post the two lists PtA and PtB to have a close look .
cmwade77
« Reply #5 on: November 25, 2014, 02:58:01 PM »
Ok, here are the list of points:
PtA - (9.34785 4.79562 9.34785 5.55109 10.2356 5.55109 10.2356 4.79562)
PtB - (9.34785 5.55109 9.34785 4.79562 10.2356 5.55109 10.2356 4.79562)
ribarm
« Reply #6 on: November 25, 2014, 03:08:01 PM »
Command: (setq lst-1 '(9.34785 4.79562 9.34785 5.55109 10.2356 5.55109 10.2356
4.79562))
Command: (setq lst-2 '(9.34785 5.55109 9.34785 4.79562 10.2356 5.55109 10.2356
4.79562))
Command: (vl-every '(lambda ( x ) (eq x T)) (mapcar '(lambda ( x ) (vl-some
T
Command: (vl-every '(lambda (q p) (equal q p 1e-8)) lst-1 lst-2)
nil
My and Tharwat's codes...
HTH
M.R. on Youtube
« Reply #7 on: November 25, 2014, 05:59:59 PM »
  2.
This can be reduced to:
  1. (vl-every '(lambda ( x ) (vl-some '(lambda ( y ) (equal x y 1e-8)) PtB)) PtA)
« Reply #8 on: November 25, 2014, 06:03:11 PM »
Or recursively,
  1. (defun f ( l1 l2 )
  2.     (or (null l1) (and (g (car l1) l2) (f (cdr l1) l2)))
  3. )
  4. (defun g ( x l )
  5.     (and l (or (equal x (car l) 1e-8) (g x (cdr l))))
  6. )
  1. (f PtA PtB)
roy_043
  • BricsCAD 18
« Reply #9 on: November 26, 2014, 05:15:58 AM »
... to see if the list points are identical...
Do you want to check if the polylines overlap? If so, the order of the points is still important. Also the OCS and the elevation should be taken into account.
Patrick_35
« Reply #10 on: November 26, 2014, 06:07:33 AM »
Hi
To compare two list without vl-every
(setq lst-1 '(9.34785 4.79562 9.34785 5.55109 10.2356 5.55109 10.2356 4.79562))
(setq lst-2 '(9.34786 4.79563 9.34786 5.55110 10.2357 5.55110 10.2357 4.79563))
(equal lst-1 lst-2 1e-4) --> T
(equal lst-1 lst-2 1e-5) --> nil
« Reply #11 on: November 26, 2014, 07:11:43 AM »
Hi
cmwade77
« Reply #12 on: November 26, 2014, 11:27:34 AM »
Hi
This only seems to work if the order is identical.
« Reply #13 on: November 26, 2014, 05:31:06 PM »
Yes,
I tried to visualise the use for comparing point lists where the point order does not matter.
.... wasn't successful.
Care to share the purpose of the test ?
roy_043
  • BricsCAD 18
« Reply #14 on: November 27, 2014, 03:22:43 AM »
