Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Convert same geometry to block
« previous
next »
Print
Pages:
1
2
All
Go Down
Author
Topic: Convert same geometry to block (Read 3685 times)
Global Moderator
Seagull
Re: Convert same geometry to block
Reply #15 on:
November 21, 2014, 03:40:40 PM »
Exactly, if you post a sample DWG file someone can see what you are up against.
Are the object a result of a copy & paste? If so they will be less coding needed to detect them.
It may require separate sub-functions for different object types.
Logged
Print
Pages:
1
2
All
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
