Hi
sorry if sometimes my questions are not precise enough.
Attached is a drawing, with one dynamic block-definition and one insert of it. The block has
- 1 visibility parameter with
- 3 visibility values.
I want to create a function which
1) selects a block-definition by its name (tblsearch?, tblobjname?)
2) analyse the visibility-parameters and values (see Lee Macs code
http://www.lee-mac.com/dynamicblockfunctions.html) and display them
3) insert the block
4) modify its visibility
All four steps seem to be clear for itself, but I have the (maybe simple) problem between step 1) and 2) - to deliver the right data to the functions in step 2). I found some postings here, but they all use "ssget" or "entsel" to select the Insert.
I hope my problem is clearer now. Thanks in advance
