DGN Purge
Hello,
I have some problems in my office that some drawing got "infected" with DGN elements.
I've found the DGNPurger utility on the Autodesk knowledge and it works fine with on drawing.
I want to create a simple loop that will open all my drawings and run the "DGNPurge " command on it.
I have created my main loop but when using the doc.SendStringToExecute nothing happened.
I thought of adding the dll as a reference to my project and simply calling the command internally but I could not find the internal main command.
I would appreciate any help on the issue.
David.
http://through-the-interface.typepad.com/through_the_interface/2013/07/autocad-dgn-hotfix-now-available.html
