What about something like this?http://www.cadtutor.net/forum/showthread.php?50344-Etransmit-lispCode - Auto/Visual Lisp: [Select](defun c:ts_Transmit (/ d yr mo day ts) (setq d (rtos (getvar "CDATE") 2 6) yr (substr d 3 2) mo (substr d 5 2) day (substr d 7 2) ts (strcat "-" day "_" mo "_" yr) ) (command "_.qsave" "_.-etransmit" "_c" (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)) ts ".zip" ) )))
(defun c:myetransmit nil (if (= 1 (getvar 'dwgtitled)) (command "_.qsave" "_.-etransmit" "_c" (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)) "-" (menucmd "m=$(edtime,0,dd.mo.yyyy)") ".zip" ) ) (princ "\nDrawing is not saved.") ) (princ))
