Author Topic: Nudge Command for ACAD2006  (Read 4804 times)
« on: November 15, 2014, 03:11:40 PM »
Wishing I had the Nudge ability in ACAD2012.
Has anyone seen a reactor that would simulate the Nudge Command?
Rod
Re: Nudge Command for ACAD2006
« Reply #1 on: November 16, 2014, 01:54:35 AM »
For me NUDGE is highlight object/s then CTRL+SHIFT+ARROW KEY.
AUTOCAD CIVIL 2015 and AUTOCAD MAP 2015 but I assumed this was a Vanilla ACAD shortcut.
or are you talking about something different?
"All models are wrong, some models are useful" - George Box
« Reply #2 on: November 16, 2014, 09:52:05 AM »
Same thing. I am using Chief Architect for a month now & it has that command.
Select an object or objects, hit [arrow] and they move a preset distance.
[Shift] [Arrow] would be 10 times the distance. Distance is in a variable.
Maybe two variables so you can set each separately.
Or three if you can use [Ctrl] [Arrow] too.
I see ACAD2012 has that feature but thought someone would have created a routine for older ACAD versions.
Did not think I would use it when it came out in ACAD but using it lately I kinda like it.
« Last Edit: November 16, 2014, 09:55:26 AM by CAB »
danallen
« Reply #3 on: November 16, 2014, 10:03:08 AM »
I have a rough shortcut routine that I use the numpad arrows to set dimension line offset at standard 3/8" * drawing scale. Uses keyboard accelerators in menu file. I haven't had time to work out right way to due with new CUI. You could modify to check if objects are selected, then issue move command.
//      menu file
***MENUGROUP=XYZ_ACCEL
***ACCELERATORS
["NUMPAD5"]^P(XYZ_keydist "get" nil)
["NUMPAD6"]^P(XYZ_keydist "0" nil)
["NUMPAD9"]^P(XYZ_keydist "45" nil)
["NUMPAD8"]^P(XYZ_keydist "90" nil)
["NUMPAD7"]^P(XYZ_keydist "135" nil)
["NUMPAD4"]^P(XYZ_keydist "180" nil)
["NUMPAD1"]^P(XYZ_keydist "-135" nil)
["NUMPAD2"]^P(XYZ_keydist "-90" nil)
["NUMPAD3"]^P(XYZ_keydist "-45" nil)
[CONTROL+"NUMPAD5"]^P(XYZ_keydist "get" 2.0)
[CONTROL+"NUMPAD6"]^P(XYZ_keydist "0" 2.0)
[CONTROL+"NUMPAD9"]^P(XYZ_keydist "45" 2.0)
[CONTROL+"NUMPAD8"]^P(XYZ_keydist "90" 2.0)
[CONTROL+"NUMPAD7"]^P(XYZ_keydist "135" 2.0)
[CONTROL+"NUMPAD4"]^P(XYZ_keydist "180" 2.0)
[CONTROL+"NUMPAD1"]^P(XYZ_keydist "-135" 2.0)
[CONTROL+"NUMPAD2"]^P(XYZ_keydist "-90" 2.0)
[CONTROL+"NUMPAD3"]^P(XYZ_keydist "-45" 2.0)
;;; lisp code
;;; XYZ_KEYDIST - Combines input distance with direction for use with numeric keypad accelerators
(defun XYZ_keydist ( ang mult / return)
  (if (and (= 0 (getvar "cmdactive")) (/= "get" ang))
    ;; pan if no command active
      (command "-pan" (getvar "viewctr") (strcat "@" (rtos (/ (getvar "viewsize") -4.0)) "<" angle))
    ;; return number if active
      (if (not mult)(setq mult 1))
      (if (or (not XYZ_KEYDIST_VALUE)
              (= ang "get")
          ) ;or
        (setq XYZ_KEYDIST_VALUE
                 (dos_getreal "Distance"
                              "Enter distance for keypad entry" ;prompt
                              7 ;no zero, negative, or null
                              (* 0.375 (getvar "dimscale"))
               ) ;cbc_getdist
        ) ;setq
      ) ;if
      (setq return (strcat "@" (rtos (* mult XYZ_KEYDIST_VALUE)) "<" ang))
  (if return return (princ))
) ;defun
« Reply #4 on: November 16, 2014, 12:30:32 PM »
Very interesting solution. Thanks for sharing.
I'll have some time tomorrow to test it out.  8)
irneb
« Reply #5 on: November 17, 2014, 07:54:09 AM »
Old one I made a while back: http://sourceforge.net/p/caddons/code/HEAD/tree/General/Editing.LSP
Uses the numpad keys to move in 45 degree directions. Distance moved depends on the zoom factor.
« Reply #6 on: November 17, 2014, 08:18:39 AM »
Thanks  Irné
I'll take a look
« Reply #7 on: May 13, 2017, 07:19:21 PM »
Well I'm back to this because I had some time today.
Decided to go with the accelerator key method.
;; CAB 05.12.2017
;;  Called from Menu Hot Keys
;;  [Ctrl]+[Right]    (NudgeObjects 0)
;;  [Ctrl]+[Left]     (NudgeObjects 180)
;;  [Ctrl]+[Up]       (NudgeObjects 90)
;;  [Ctrl]+[Down]     (NudgeObjects 2700)
;;  [Ctrl]+[5]        (NudgeObjects -1)  Edit Nudge Distance
(defun NudgeObjects ( ang / ss sel p1 p2 )
  (if (not NudgeDist) (setq NudgeDist 1.0)) ; Globle Variable
  (setq ss (cadr(ssgetfirst))) ;  get anything already selected
    ((< ang 0)  (setq NudgeDist (getdist "/nEnter new Nudge diatance : ")))
    ((= 0 (getvar "cmdactive"))  ; MOVE if no command active
        (if (and (null ss) (not (prompt "\nSelect the objects to move: ")))
                (setq ss (ssget "_:L"))   )
        (setq p1 (vlax-3D-point (trans '(0 0) 1 0))
                 p2 (vlax-3D-point (trans (polar '(0 0) (/ (* ang pi) 180.0) NudgeDist) 1 0))
        (vlax-for obj  (setq sel (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))))
            (vl-catch-all-apply 'vla-move (list obj p1 p2))
        (vla-Delete sel)
       (sssetfirst nil ss) ; activate the selection set again
  ) ; cond
) ; defun
BIGAL
  • 40 + years of using Autocad
« Reply #8 on: May 13, 2017, 08:18:57 PM »
This is similar chx chy chz done 1997
(defun C:CHX ()
  (SETVAR "CMDECHO" 0)
  (setq sn (getvar "osmode"))
  (command "osnap" "near")
  (setq x 0)
  (princ "\nalters object in X direction")
  (setq ht (getstring "\n What is amount of change: "))
  (setq newht (strcat ht ",0"))
  (while (= x 0)
    (setq newobj (entsel "\nPoint to object: "))
    (if (/= newobj nil)
    (command "move" newobj "" "0,0" newht)
  (if (= newobj nil)(setq x 1))
Grrr1337
« Reply #9 on: May 14, 2017, 04:57:02 AM »
@CAB its impressive that you've done it without (grread)
BTW Thanks to you (or some old code example of yours) I managed to learn (grread), so heres another approach:
  1. (defun C:test ( / f SS grr Stop d k tmp )
  2.
  3.   (setq d 50) ; default nudge distance
  4.
  5.   (setq f
  6.     (lambda (SS d k / a p1 p2 i )
  7.       (and (setq a (cadr (assoc k '(("W" 90) ("S" 270) ("A" 180) ("D" 0)))))
  8.         (setq p1 (vlax-3D-point (trans '(0 0) 1 0))) (setq p2 (vlax-3D-point (trans (polar '(0 0) (/ (* a PI) 180.0) d) 1 0)))
  9.         (repeat (setq i (sslength SS)) (vla-Move (vlax-ename->vla-object (ssname SS (setq i (1- i)))) p1 p2) )
  10.       ); and
  11.     ); lambda
  12.   ); setq f
  13.
  14.   (and (princ "\nSelect objects to nudge: ") (setq SS (ssget "_:L-I")) (sssetfirst nil nil)
  15.     (princ "\nPress [W/A/S/D] keys to nudge the SS | [TAB] to set new distance | [ENTER/RMB/LMB] if done: ")
  16.     (while (not Stop) (setq grr (grread)) (and (or (equal grr '(2 13)) (member (car grr) '(3 25))) (setq Stop T))
  17.       (cond ( (/= (car grr) 2) )
  18.         ( (setq k (strcase (chr (cadr grr))))
  19.           (if (= k "\t") (if (setq tmp (getdist "\nSpecify new distance: ")) (setq d tmp)) (f SS d k) )
  20.         )
  21.       ); cond
  22.     ); while
  23.   ); and
  24.   (princ)
  25. ); defun C:test
Do you guys ever played Counter-Strike? Try using <W> <A> <S> <D> keys for nudging/moving its quite easy. :)
(apply ''((a b c)(a b c))
vevo.bg
chisinwolf
  • Mosquito
« Reply #10 on: December 10, 2018, 11:01:48 PM »
  2.
  4.
  5.   (setq f
  10.       ); and
  11.     ); lambda
  12.   ); setq f
  13.
  20.         )
  21.       ); cond
  22.     ); while
  23.   ); and
  24.   (princ)
  25. ); defun C:test
This code is very useful for me.
Is there any way to add a Regen immediately after each individual nudge? Always after each nudge before exiting?
In any event thank you Grrr1337 for this code.
ribarm
  • Marko Ribar, architect
« Reply #11 on: December 11, 2018, 03:47:38 AM »
  (setq f
      ); and
    ); lambda
  ); setq f
          (if (= k "\t") (if (setq tmp (getdist "\nSpecify new distance: ")) (setq d tmp)) (progn (f SS d k) (vl-cmdf "_.REGEN")) )
      ); cond
    ); while
  ); and
); defun C:test
HTH., M.R.
M.R. on Youtube
chisinwolf
  • Mosquito
« Reply #12 on: December 11, 2018, 06:49:39 AM »
Hi Marko,
That works exactly how I wanted.
Thank you for taking time to help me.
Cheers.
GDF
« Reply #13 on: December 11, 2018, 07:28:56 PM »
Awesome Marko
