Author Topic: Navisworks Appearance Profiler not applying color  (Read 9549 times)
Krushert
  • FREE BEER Tomorrow!!
« on: November 12, 2014, 10:53:32 AM »
Navisworks Manage 2014 Appearance Profiler not applying color to all items in the search set even though the search set is selecting those objects.   I think (a guess here) that the color is hard coded to the Revit Material.   Screen shot below shows pipes that are not coloring but the fitting and valves are.  The pipes are system families in Revit MEP.  I also have this problem with stairs.
Do I have to switch something Revit or do I do it in Navisworks?
I no longer CAD or Model, I just hang out here for camaraderie
Matt__W
  • I like my water diluted.
Re: Navisworks Appearance Profiler not applying color
« Reply #1 on: November 12, 2014, 11:00:10 AM »
Is your view set to FULL RENDER or SHADED?
Autodesk Expert Elite
Krushert
« Reply #2 on: November 12, 2014, 11:45:47 AM »
Was in Full Render. Change it to Shaded and the pipes were now color as desired.
But Shaded mode is not desired.  Will need it in the Full Render Mode.
Matt__W
« Reply #3 on: November 12, 2014, 11:54:00 AM »
Why do you have to view it in FULL RENDER mode?  Why not leave it in SHADED mode and create renderings (if need be)?  Shaded mode is a LOT faster to navigate, too.
Krushert
« Reply #4 on: November 12, 2014, 12:00:59 PM »
Because of the Client.  The client will be getting the NW Model for their use, AKA to run scenarios on all those yellow points.
Matt__W
« Reply #5 on: November 12, 2014, 01:11:43 PM »
Did the client specifically request the Navisworks model be in realistic mode?  If not, don't give it to them that way.  They stand to gain NOTHING by checking for clashes with materials displayed on everything.  NOTHING.  And like I said before, the overall navigation within the model with be significantly slower in a realistic mode than in the shaded mode.
Krushert
« Reply #6 on: November 12, 2014, 01:30:10 PM »
They did not specifically request it but they do want to differentiate the material of objects.  CMU wall vs Metal Panel vs Plastic.  With Shaded setting, all the walls and steel are the same color.   I am dealing with non-Revit &non-Navisworks users here and I am trying to keep things as simple as possible.  (There will be a bunch of scientists and lawyers over schmuck's shoulder and they will need as much rendering as possible to "guide" them through the model.)  Second I do not want to create a bunch of Appearance Profiles For all the material in the model.  Third I do not care rat's butt about navigation speed for them.   4th there will be no clash detection done.  This is just a pretty picture to them to see what the yellow node is attached to.
Matt__W
« Reply #7 on: November 12, 2014, 01:37:05 PM »
Then why not simply use Revit?  You can use Revit in viewer mode so you won't need a license.  You'll get all of the materials displaying correctly and you won't have to worry about exporting to a different file format, modifying, etc....  Why complicate things?
Krushert
« Reply #8 on: November 12, 2014, 01:43:50 PM »
Just because!
Matt__W
« Reply #9 on: November 12, 2014, 01:46:42 PM »
Krushert
« Reply #10 on: November 12, 2014, 01:57:57 PM »
 :2funny: :2funny: :2funny:
my feelings towards you as well.
To properly explain this project, it will have to be over discussion that consist of more beer that I owe you now.
Krushert
« Reply #11 on: November 12, 2014, 02:22:19 PM »
So if I go into Revit and into the stair family, toggle the material to "By Category".  ReExport to NW and then run Profiler, the stairs will color as desired.  But It screws over my Revit model in properly showing the material there.  Dam if I do ~ Dam if I don't
Krushert
« Reply #12 on: November 13, 2014, 01:51:51 PM »
So I fixed the stairs but dammed if I can find where I can control the material for Pipes in Revit MEP.
So I decided to stop fighting and just change the fittings to match the pipes using the Appearance Profiler. I am bummed that I could not get use the pink fuchsia.   :-P
Matt__W
« Reply #13 on: November 13, 2014, 01:58:25 PM »
Manage --> Object Styles will control the material on a global basis.
Matt__W
« Reply #14 on: November 13, 2014, 02:01:28 PM »
OR.... you can scroll down to the Families section of the Project Browser and locate the Piping Systems section.  From there you can change the material of entire systems.
