Jeff's answer is correct.
However, before you can call DBObject.Erase(false), you need to make sure you call correct overriden Transaction.GetObject() (e.g. with a third boolean argument passed in as "true").
Here is code showing that:
using CadApp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof(EraseAndUnerase.MyCadCommands))]
namespace EraseAndUnerase
public class MyCadCommands
[CommandMethod("TestErase")]
public static void RunMyCadCommand()
Document dwg = CadApp.DocumentManager.MdiActiveDocument;
if (dwg == null) return;
Editor ed = dwg.Editor;
try
PromptSelectionResult res = ed.GetSelection();
if (res.Status == PromptStatus.OK)
ObjectId[] ids = res.Value.GetObjectIds();
EraseEntities(dwg, ids, true);
ed.UpdateScreen();
ed.GetString(
"\nAll selected entities have been erased.\nPress any key to unerase them...");
EraseEntities(dwg, ids, false);
ed.UpdateScreen();
catch (System.Exception ex)
ed.WriteMessage("\nError: {0}\n{1}", ex.Message, ex.StackTrace);
finally
Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
private static void EraseEntities(Document dwg, ObjectId[] entIds, bool erasing)
using (var tran=dwg.TransactionManager.StartTransaction())
foreach (var id in entIds)
Entity ent;
if (erasing)
if (!id.IsErased)
ent = (Entity)tran.GetObject(id, OpenMode.ForWrite);
ent.Erase(); //or ent.Erase(true);
else
if (id.IsErased)
ent = (Entity)tran.GetObject(id, OpenMode.ForWrite, true);
ent.Erase(false);
tran.Commit();
