Hi, im looking for a program / code to print rimless PDFs.
This is what i made, but i have big trouble because the pdfs often come with the wrong direction
I make a new plotconfig with (vla-add( ....)) and modify it with following methods
(defun plotWindow (doc config / point1 point2 pointTemp1 pointTemp2 entlistConfig)
(setq point1 (vlax-variant-value (vla-GetPoint (vla-get-Utility doc) nil "Links unten")))
;; 3d-Punkt zu 2d-Punkt
(setq pointTemp1 (vlax-make-safearray vlax-vbDouble '(0 . 1)))
(vlax-safearray-put-element pointTemp1 0 (vlax-safearray-get-element point1 0))
(vlax-safearray-put-element pointTemp1 1 (vlax-safearray-get-element point1 1))
(setq point2 (vlax-variant-value (vla-GetCorner (vla-get-Utility doc) point1 "Rechts oben")))
(setq pointTemp2 (vlax-make-safearray vlax-vbDouble '(0 . 1)))
(vlax-safearray-put-element pointTemp2 0 (vlax-safearray-get-element point2 0))
(vlax-safearray-put-element pointTemp2 1 (vlax-safearray-get-element point2 1))
(vla-SetWindowToPlot config pointTemp1 pointTemp2)
;; Fenstermodus beim Drucken
(vla-put-PlotType config acWindow)
(list (vlax-safearray->list pointTemp1)(vlax-safearray->list pointTemp2))
(defun paperSize (doc config lstPoints / pt1 pt2)
(setq pt1 (nth 0 lstPoints)
pt2 (nth 1 lstPoints)
deltaX (- (car pt2) (car pt1))
deltaY (- (cadr pt2)(cadr pt1))
(vla-put-ConfigName config "PDF24 PDF.pc3")
(if (= (getvar "ctab") "Model")
(modPaperSize)
(vla-put-PlotOrigin config (vlax-safearray-fill (vlax-make-safearray vlax-vbDouble '(0 . 1)) (list 0.0 0.0)))
(setq entlistConfig (entget (vlax-vla-object->ename config))
entlistConfig (entmod (subst (cons 44 deltaX) (assoc 44 entlistConfig) entlistConfig))
entlistConfig (entmod (subst (cons 45 deltaY) (assoc 45 entlistConfig) entlistConfig))
Would be nice if someone had an idea how i can go on to print the pdfs ...
mfg matthias
