Hi everyone,
So here is my problem of the week. I work with a program called 3D-office and AutoCAD Civil 3d. Usually I import data (3D poly lines, points, ...etc) from autocad into 3D-Office and build surfaces (because it is much easier to build complex surface in 3D-Office). Now for the first time I am trying to bring a Surface from 3D-Office to AutoCAD however the format is strange. Its as if the TIN surface has been turned into 3 dimensional linework of the surface (like exploding a surface into lines.). I was wondering if there is a away to turn these lines into a surface again in AutoCAD. PM me if you want to see the file!
Thank you in advance.
-David
