Author Topic: vl-file-systime does not work on open file  (Read 3659 times)
ahankhah
« on: November 05, 2014, 01:55:17 AM »
    Hi all,
    Although vl-file-systime works fine on most files (even readonly ones), it doesn't work on open files.
    Could any one introduces alternatives to vl-file-systime function to get the time of such files?
    I appreciate any help and clues to solve the problem
irneb
Re: vl-file-systime does not work on open file
« Reply #1 on: November 05, 2014, 02:33:30 AM »
You could use the ActiveX file system object:
  1. (defun file-property (path prop / fso f p)
  2.   (vl-catch-all-apply '(lambda ()
  3.                          (setq fso (vlax-get-or-create-object "Scripting.FileSystemObject")
  4.                                f   (vlax-invoke fso "GetFile" path)
  5.                                p   (vlax-get f prop))))
  6.   (vl-catch-all-apply 'vlax-release-object (list f))
  7.   (vl-catch-all-apply 'vlax-release-object (list fso))
  8.   p)
  9.
  10. (defun file-DateCreated (path) (file-property path "DateCreated"))
  11. (defun file-DateLastAccessed (path) (file-property path "DateLastAccessed"))
  12. (defun file-DateLastModified (path) (file-property path "DateLastModified"))
Note it returns some "weird" date/time real instead of the y/m/d/etc. or even a proper standard date/time real. To convert it so it's actually useful look here: http://forums.augi.com/showthread.php?120360-Find-creation-date-of-folder
« Last Edit: November 05, 2014, 05:36:12 AM by irneb »
« Reply #2 on: November 05, 2014, 04:06:57 AM »
Please search the forum before posting a new thread  :-)
http://www.theswamp.org/index.php?topic=43559.msg488184#msg488184
ahankhah
« Reply #3 on: November 05, 2014, 05:09:14 AM »
Irneb, thank you very much.
Lee, thank you too. You are right. Of course I searched internet by google with no success to find any reply.
« Reply #4 on: November 05, 2014, 08:35:02 AM »
Use google advanced search  http://www.google.com/advanced_search?hl=en
and paste this in the site or domain:  http://www.theswamp.org/index.php?board=2.0 to search the Swamp Lisp board
« Reply #5 on: November 05, 2014, 08:45:24 AM »
ahankhah
« Reply #6 on: November 05, 2014, 10:47:30 AM »
lmgtfy ...
CAB, MP, thank you. I appreciate your help.
