Author Topic: fill scalebar tags  (Read 12522 times)
Re: fill scalebar tags
« Reply #45 on: November 10, 2014, 02:43:11 AM »
Here is an error
  1. (defun c:test3 (/ b bname p scale)         ;scalebar
  2.  < .. >
  3.
[CHECKING TEXT <Untitled-0> loading...]
; error: malformed list on input
; Check done.
That's because you stuffed up the parenthesis when you edited my code.
Kerry is it possible to add a filter and when the scale is
50,150,250,350,450,650,...... then use this math for D2
(cons "D2" (strcat (rtos (/ scale 100) 2 1)))
Yes, options
  1. (if (= 50 (rem scale 100.))
  2.          (cons "D2" (strcat (rtos (/ scale 100.) 2 1)))
  3.          (cons "D2" (strcat (rtos (/ scale 100) 2 0)))
  4. )
  5.
  1. (if (vl-position scale (list 50 150 250 350 450 650))
  4. )
  5.
I'm wondering why you don't use one decimal place typically.
Why did you remove the decimal place from my multiplication and division calcs ?
« Last Edit: November 10, 2014, 03:42:16 AM by Kerry »
pedroantonio
« Reply #46 on: November 10, 2014, 02:56:18 AM »
something is wrong here
  1. (lm:vl-setattributevalue b "D1" (strcat (rtos (/ scl 50) 2 0)))
  2. ;(lm:vl-setattributevalue b "D2" (strcat (rtos (/ scl 100) 2 0)))
  3. (if (vl-position scl (list 50 150 250 350 450 650))
  4.          (cons "D2" (strcat (rtos (/ scl 100.) 2 1)))
  5.          (cons "D2" (strcat (rtos (/ scl 100) 2 0)))
  6. )
  7. (lm:vl-setattributevalue b "D3" (strcat (rtos (/ scl 50) 2 0)))
  8. (lm:vl-setattributevalue b "D4" (strcat (rtos (* (/ scl 50) 2) 2 0)))
  9. (lm:vl-setattributevalue b "D5" (strcat (rtos (* (/ scl 50) 3) 2 0)))
  10. (lm:vl-setattributevalue b "D6" (strcat (rtos (* (/ scl 50) 4) 2 0)))
  11. (lm:vl-setattributevalue b "D7" (strcat (rtos (/ scl 10) 2 0)))
  12. (lm:vl-setattributevalue b "SCALE" (strcat (rtos scl 2 0)))
  13. (setvar 'attreq 1)
  14. )
  15. )
  16.
« Last Edit: November 10, 2014, 03:03:01 AM by Topographer »
pedroantonio
« Reply #47 on: November 10, 2014, 03:16:45 AM »
 Why in D2 gives me 2.0 and not 2.5 for scale 250 ?
I have changes the maths to
(lm:vl-setattributevalue b "D2" (strcat (rtos (/ scl 100) 2 1)))
« Reply #48 on: November 10, 2014, 03:40:42 AM »
For the fifteenth time , change
(/ scl 100)
to
(/ scl 100. )
When you divide integers the result will be an integer .. rounded
(/ 9 7)   ;-> 1
(/ 5 2 )  ;-> 2
(/ 9. 7 ) ;-> 1.28571
(/ 5. 2 ) ;-> 2.5
http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-E9E70DA9-6048-470D-B899-239B097671D2
pedroantonio
« Reply #49 on: November 10, 2014, 04:27:11 AM »
how to use this ?
  4. )
  5.
  6.
is not working
(setvar 'attreq 1)
« Reply #50 on: November 10, 2014, 04:36:51 AM »
I tested it like this :
  1. ;;;; Concept code :  kdub@theSwamp Nov2014
  2. (defun c:test3a (/ b bname p scale TagData )          ;scalebar
  3.   (if (and (setq scale (getint "\nEnter scale to use: "))
  4.            (setq p (getpoint "\nSelect insert point for scale bar:"))
  5.            (setq bname (findfile "test.dwg"))
  6.       )
  7.     (progn (command "_layer" "_m" "scale" "_c" "7" "" "")
  8.            (setvar 'attreq 0)
  9.            (command _"insert" bname p scale scale "0")
  10.            (setq b (vlax-ename->vla-object (entlast)))
  11.            (setq TagData (list (cons "D1" (strcat (rtos (/ scale 50) 2 0)))
  12.                                (if (= 50 (rem scale 100))
  13.                                  ;; (vl-position scale (list 50 150 250 350 450 650))
  14.                                  (cons "D2" (strcat (rtos (/ scale 100.) 2 1)))
  15.                                  (cons "D2" (strcat (rtos (/ scale 100) 2 0)))
  16.                                )
  17.                                (cons "D3" (strcat (rtos (/ scale 50) 2 0)))
  18.                                (cons "D4" (strcat (rtos (* (/ scale 50) 2) 2 0)))
  19.                                (cons "D5" (strcat (rtos (* (/ scale 50) 3) 2 0)))
  20.                                (cons "D6" (strcat (rtos (* (/ scale 50) 4) 2 0)))
  21.                                (cons "D7" (strcat (rtos (/ scale 10) 2 0)))
  22.                                (cons "SCALE" (strcat (rtos scale 2 0)))
  23.                          )
  24.            )
  25.            (kdub:setattributes b TagData)
  26.            (setvar 'attreq 1)
  27.     )
  28.   )
  29. )
  30.
  31.
pedroantonio
« Reply #51 on: November 10, 2014, 04:51:45 AM »
           (setvar 'attreq 0)
           (setvar 'attreq 1)
This code is not filling the tags in my Autocad 2010 !!
« Reply #52 on: November 10, 2014, 04:59:30 AM »
I don't have ac2010, so can't test.
Did you load the kdub:setattributes function ?
What scale did you use ?
Were there any error messages ?
Was it working previously ?
etc, etc,
« Last Edit: November 10, 2014, 05:05:59 AM by Kerry »
pedroantonio
« Reply #53 on: November 10, 2014, 05:21:41 AM »
Where i can find the kdub:setattributes function ?
can you post it ?
pedroantonio
« Reply #54 on: November 10, 2014, 05:23:21 AM »
sorry i find it
pedroantonio
« Reply #55 on: November 10, 2014, 05:36:32 AM »
Thank you Kerry.The code works fine now    :lmao:
« Reply #56 on: November 10, 2014, 06:26:56 AM »
can you post it ?
Yes.  :|
