Author Topic: ENTMAKE function  (Read 68087 times)
ElpanovEvgeniy
  • Moscow (Russia)
Re: ENTMAKE function
« Reply #60 on: April 05, 2007, 11:58:15 PM »
This is done by stripping the unwanted dxf codes from the entlist before writing the list to the lisp file.
What for?
It is possible to leave a full code - all will work!
For example, my variant of copying of objects on base LISP, as vla-copy
(entmakex(entget(car(entsel))))
« Reply #61 on: April 06, 2007, 07:18:02 AM »
Perhaps I have not understood the entmakex function.
In my test with entmake, some entities would not make unless I removed some of the dxf codes. Testing was done in ACAD2000.
Keep in mind that the entity list created by my routine are written to a lisp file and may be used to create the cloned entity in another drawing and or space.
I primarily use it to create an entmake to be added to a lisp routine so I can create the entity for the first time in a drawing.
Are you are telling me that if I use entmakex I may leave all the dxf codes in without penalty?
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #62 on: April 06, 2007, 07:25:20 AM »
Yes! :)
For 2004-2008 acad...
« Reply #63 on: April 06, 2007, 07:30:03 AM »
OK, that clears that up. Thanks.
I need to move into the present. :-) Or at least ACAD2006.
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #64 on: April 14, 2007, 03:33:45 AM »
Creation of hatch with the instruction of a pattern, a angle and scale.
(defun entmakex-hatch (L a n s)
 ;; By ElpanovEvgeniy
 ;; L - list point
 ;; A - angle hatch
 ;; N - name pattern
 ;; S - scale
 ;; returne - hatch ename
 (entmakex
  (apply
   'append
   (list
    (list '(0 . "HATCH")
          '(100 . "AcDbEntity")
          '(410 . "Model")
          '(100 . "AcDbHatch")
          '(10 0.0 0.0 0.0)
          '(210 0.0 0.0 1.0)
          '(2 . "ANSI31")
          (if (= n "SOLID")
           '(70 . 1)
           '(70 . 0)
          ) ;_  if
          '(71 . 0)
          (cons 91 (length l))
    ) ;_  list
    (apply 'append
           (mapcar '(lambda (a)
                     (apply 'append
                            (list (list '(92 . 7) '(72 . 0) '(73 . 1) (cons 93 (length a)))
                                  (mapcar '(lambda (b) (cons 10 b)) a)
                                  '((97 . 0))
                            ) ;_  list
                     ) ;_  apply
                    ) ;_  lambda
                   l
           ) ;_  mapcar
    ) ;_  apply
    (list '(75 . 0)
          '(76 . 1)
          (cons 52 a)
          (cons 41 s)
          '(77 . 0)
          '(78 . 1)
          (cons 53 a)
          '(43 . 0.)
          '(44 . 0.)
          '(45 . 1.)
          '(46 . 1.)
          '(79 . 0)
          '(47 . 1.)
          '(98 . 2)
          '(10 0. 0. 0.0)
          '(10 0. 0. 0.0)
          '(451 . 0)
          '(460 . 0.0)
          '(461 . 0.0)
          '(452 . 1)
          '(462 . 1.0)
          '(453 . 2)
          '(463 . 0.0)
          '(463 . 1.0)
          '(470 . "LINEAR")
    ) ;_  list
   ) ;_  list
  ) ;_  apply
 ) ;_  entmakex
) ;_  defun
Check:
(entmakex-hatch '(((538.794 584.563) (895.629 584.563) (895.629 997.377) (538.794 997.377))
                  ((386.809 345.13) (670.955 345.13) (670.955 855.369) (386.809 855.369))
                (/ pi 2)
                "ANSI31"
                2.
) ;_  entmakex-hatch
(entmakex-hatch
 (list
  (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget (car (entsel)))))
 ) ;_  list
 (/ pi 2)
 "ANSI31"
 2.
KewlToyZ
« Reply #65 on: December 06, 2007, 10:31:18 PM »
I'm curious why you chose 2006 CAB?
2004 was blazing fast, 2006 added the cui but retained 2004 file formatting.
2007 refined use of the cui menu files created in 2006 and interface formatting had the maximum use for ToolPalette flexibility.
You could actually still export to xtp files for other users to import. Which was very beneficial in a network environment. The reason I mention those items for 2007 was you could actually use a routine like this to create a drawing that could then be used to export an entire tool palette of the objects in the drawing for use later through Design Center. Where it would be necessary I have not the foggiest but I'm sure people run into some obstacles this could shortcut considerably.
2008 disables the toolpalette export function...
« Last Edit: December 06, 2007, 10:38:57 PM by KewlToyZ »
« Reply #66 on: December 07, 2007, 12:35:17 AM »
Because I already own a copy of 2006 8-)
KewlToyZ
« Reply #67 on: December 07, 2007, 08:14:56 PM »
LOL gotcha!  :lmao:
Pricing does have its woes.
I'm on subscription for 80 some licenses...talk about a major wallet hole that is.... :-o
Thanks CAB
wizman
« Reply #68 on: December 09, 2007, 05:32:35 AM »
THIS IS AMAZING, THANKS FOR SHARING, NOW I DONT HAVE TO WORRY IN MY ENTMAKE.
taner
« Reply #69 on: December 09, 2007, 06:57:58 PM »
Dear CAB,
what difference between your function replace and Subst?tks!
« Last Edit: April 05, 2011, 08:34:56 AM by CAB »
« Reply #70 on: December 09, 2007, 08:50:24 PM »
Been too long ago for my short memory, I'll have to look at it on Monday.
taner
« Reply #71 on: February 06, 2009, 10:18:49 PM »
Many monday have past!
« Reply #72 on: February 06, 2009, 11:25:25 PM »
Many moons have past.  8-)
Looks like they do the same thing.
TimSpangler
  • CAD Naked!!
« Reply #73 on: March 09, 2009, 12:22:02 PM »
Emake Wipeouts
Thanks to Joe Burke and Gile and a bit of TT I believe
Works great, not sure which versions it works in.  Maybe some testing will tell.
ACA 2015 - Windows 7 Pro
flopo
« Reply #74 on: April 05, 2011, 06:32:48 AM »
Helo Cab,
I want to use your lisp entmake with a macro to insert some objects in a drawing. When i generate the lisp that create those objects, i move them somewhere centered to 0,0,0 point - origin. I do this because i want to insert those object in a point that i will select on the drawing - and always those objects are drawn in their original locations, even if i change my ucs (with a small lisp). How can i insert those objects created with your entmake lisp in a point chosen on the drawing? Thanks!
