Author Topic: Scaling by reference in separate directions.  (Read 4140 times)
DPATTERSON
« on: October 29, 2014, 02:45:50 PM »
Hi Everyone!
I have to scale by reference but in two separate direction.  So first only scale the Y then scale the X.  Please tell me their is a way to do this!
-David :D
Re: Scaling by reference in separate directions.
« Reply #1 on: October 29, 2014, 03:05:17 PM »
first I must ask WHY?  in a Civil drawing you would be doing this
Then, suggest
first figure out what those separate scale factors are...
then insert the data as a block and apply non-uniform scale *note this may or may not result in usable information
as the block may not explode
RC
« Reply #2 on: October 29, 2014, 04:07:10 PM »
SCALE reference in one direction then note (Copy) the scale factor of the block in that direction.
The SCALE reference in the other direction.
Select the block and in the properties window paste the value of the previous scale in the appropriate box.
« Reply #3 on: October 29, 2014, 04:22:28 PM »
and Again no guarantee that the then non-uniformed block will allow exploding IF one then wants to work on the entities that comprised the block
RC
« Reply #4 on: October 29, 2014, 04:36:20 PM »
Why would you want to explode a block if you went to all the trouble of making it a block to start with??
If it is a block, copy it to another location return scales to uniformity and REFEDIT that instance.  Once complete delete the copy and the non-uniformly scaled block will be up to date.
« Reply #5 on: October 29, 2014, 04:39:24 PM »
user never said the item(s) were in a block....given that it is a CIVIL drawing user may want and or need to work with these components as entities not as a block AFTER the non-uniform scale operation succeeds
RC
« Reply #6 on: October 29, 2014, 04:42:28 PM »
you are correct, I was reading the scale as in scale a block, my apologies.
DPATTERSON
« Reply #7 on: November 07, 2014, 09:10:43 AM »
Thanks I figured it out!  I had to xref in an old .pdf and it was so wacky that the x scale and y scale were different.
 :-D
« Reply #8 on: November 07, 2014, 09:16:05 AM »
 :-D
It might have been easier to convert to image and use Rubber Sheeting to adjust to fit actual coordinates.
For future reference.
Thanks for the update.
