Author Topic: Why snap not working with insertion point of nested block?  (Read 5779 times)
HasanCAD
« on: October 29, 2014, 11:47:35 AM »
I created this block with array(attached).
this morning I was able to snap to insertion point of nested block, But now I can not.
ChrisCarlson
Re: Why snap not working with insertion point of nested block?
« Reply #1 on: October 29, 2014, 11:57:13 AM »
I don't think you can? The insertion point of that block Wall-RFT-150-WO-STRG is the bottom left.
HasanCAD
« Reply #2 on: October 29, 2014, 12:02:25 PM »
I was able to snap to the nested block (Cyan circle ) but now can not.
snap was working for insertion point of nested block.
« Reply #3 on: October 29, 2014, 12:41:36 PM »
why do you want to?
perhaps a vis state that only shows that nested block?
HasanCAD
« Reply #4 on: October 29, 2014, 12:54:16 PM »
This DB showing the bars (for plan section detail - we drafting structural design drawing) I add this blocl then add stirrup (It id as DB too).
RC
« Reply #5 on: October 29, 2014, 01:14:33 PM »
I cannot snap to it either. if you kept a circle around the hatch in the 'SS' block definition you could snap to center.
Redefine block SS to be a donut (pline) with a center radius of 0 and a diameter of 1, and you can snap to center.  the osnap to insert is snapping to the insertion of the whole block not the nested.  I have never been able to osnap to a nested insert for anything except text.
HasanCAD
« Reply #6 on: October 29, 2014, 01:39:54 PM »
OK that is good temper solution. Working fine.
But I want to know the reason of that.
RC
« Reply #7 on: October 29, 2014, 01:59:55 PM »
As I said, I have never been able to osnap to a nested insertion point for anything except text.  Osnap INSertion will find the insertion point of the whole dynamic block, how would it ever know you were looking for a nested insert??
(That said you can toggle GRIPS for nested elements on and off with GRIPBLOCK)
« Reply #8 on: October 29, 2014, 02:09:17 PM »
Why wouldn't you want to snap to any object ?
Instances where that particular object should not be used as a grip and or alignment entity.
HasanCAD
« Reply #9 on: October 29, 2014, 02:31:16 PM »
Is it mean I was dreaming!?!?!?
RC
« Reply #10 on: October 29, 2014, 04:02:58 PM »
Building a block that has objects to snap to is a plus in my book. If you don't want to snap to them then press F3 (unless your snaps are already off LOL ):P
Just because you don't wish to snap to PARTS of a block doesn't mean you don't wish to snap to other parts, besides F3 is ONLY running OSNAP and does nothing for 'real' OSNAP.  ;)
« Reply #11 on: October 29, 2014, 04:20:57 PM »
no, he is saying one could STILL use snap overrides even IF OSNAP is toggled OFF with the F3 key
RC
« Reply #12 on: October 29, 2014, 04:39:30 PM »
Just because you don't wish to snap to PARTS of a block doesn't mean you don't wish to snap to other parts, ....  ;)
I don't understand what you're talking about. Are you agreeing with me?
no not really, you seem to indicate that if one doesn't wish to OSNAP to a particular point on a block one should just turn off OSNAPPING all together (F3)
RC
« Reply #13 on: October 29, 2014, 04:40:21 PM »
Isn't that kind of a 'DUH' statement? Seems like if you enter a snap mode, you know what you want to snap to. Anyhoo .. I've had enough chat about snaps .. carry on.  :2funny:
and therein lies my point, F3 has nothing to do with it
HasanCAD
« Reply #14 on: October 30, 2014, 03:50:03 AM »
instead of pline I draw a line with length 0 mm in insertion point of block. I believe it is better to snap
