Author Topic: Alignment from object in profile layout?  (Read 2558 times)
DPATTERSON
« on: October 23, 2014, 12:40:39 PM »
Hello everyone,
I wanted to know if I can create a profile layout from a polyline in the profile view.  I am creating two options for an access road.  The first option has a 200m alignment with a curve, the second option has a T intersection with a dead end and 2 alignments.  I want to have the profile layout of the first alignment in option 1 to be the same as the profile layout in option 2.  Any Advice?
- David
Re: Alignment from object in profile layout?
« Reply #1 on: October 23, 2014, 12:45:02 PM »
That function doesn't really function....
However investigate using SUPERIMPOSED profile to place option 1 profile into option 2 profile view
then you can target that profile in option 2 corridor design
« Reply #2 on: October 23, 2014, 12:46:44 PM »
or build each option as a single corridor....
through creative layering one could show each in different viewport.....
advanced use of code set styles required
could be far more elegant way to proceed
