Author Topic: Parcing a filename into a block  (Read 8466 times)
Re: Parcing a filename into a block
« Reply #15 on: October 22, 2014, 03:39:06 PM »
Lee,
I like the Lisp, but I can not adjust the acaddoc.lsp. I do not have rights.  I can use it on my machine. But again, what we're .....
Maybe talk to the person that can give you rights. I agree that lisp is the best way to approach this, and Lee's already given you the solution. Beating dead horses has never been fun.  :P
DIW_CADtech
  • Push limits, embrace success, & discard failure.
« Reply #16 on: October 22, 2014, 03:46:21 PM »
 :oops:
WAVES WHITE FLAG...................
I am very  trainable....   (forgive my spelling)
« Reply #17 on: October 22, 2014, 06:11:39 PM »
If I can cover 95% of the possibilities.. than I still have something worth while.
unit .. up to 3 char
disc 1 char
type 2 char
syst 3 char
Number 5-7 char (I know this one's going to be a *****)
sheet 1-4 char
I don't know what the max lenth of DIESEL code is but I'm pretty sure it's pretty long.. I think beyond 255 char.
With these additional restrictions on section string lengths, you can use the following DIESEL expressions:
Unit 1-3 chars
$(if,$(eq,-,$(substr,$(getvar,dwgname),2,1)),$(substr,$(getvar,dwgname),1,1),$(if,$(eq,-,$(substr,$(getvar,dwgname),3,1)),$(substr,$(getvar,dwgname),1,2),$(if,$(eq,-,$(substr,$(getvar,dwgname),4,1)),$(substr,$(getvar,dwgname),1,3))))
Disc 1 char
$(if,$(eq,-,$(substr,$(getvar,dwgname),2,1)),$(substr,$(getvar,dwgname),3,1),$(if,$(eq,-,$(substr,$(getvar,dwgname),3,1)),$(substr,$(getvar,dwgname),4,1),$(if,$(eq,-,$(substr,$(getvar,dwgname),4,1)),$(substr,$(getvar,dwgname),5,1))))
Type 2 chars
$(if,$(eq,-,$(substr,$(getvar,dwgname),2,1)),$(substr,$(getvar,dwgname),5,2),$(if,$(eq,-,$(substr,$(getvar,dwgname),3,1)),$(substr,$(getvar,dwgname),6,2),$(if,$(eq,-,$(substr,$(getvar,dwgname),4,1)),$(substr,$(getvar,dwgname),7,2))))
Syst 3 chars
$(if,$(eq,-,$(substr,$(getvar,dwgname),2,1)),$(substr,$(getvar,dwgname),8,3),$(if,$(eq,-,$(substr,$(getvar,dwgname),3,1)),$(substr,$(getvar,dwgname),9,3),$(if,$(eq,-,$(substr,$(getvar,dwgname),4,1)),$(substr,$(getvar,dwgname),10,3))))
I also have the following for Sheet 1-4 chars:
$(if,$(eq,-,$(substr,$(getvar,dwgname),$(-,$(strlen,$(getvar,dwgname)),5),1)),$(substr,$(getvar,dwgname),$(-,$(strlen,$(getvar,dwgname)),4),1),$(if,$(eq,-,$(substr,$(getvar,dwgname),$(-,$(strlen,$(getvar,dwgname)),6),1)),$(substr,$(getvar,dwgname),$(-,$(strlen,$(getvar,dwgname)),5),2),$(if,$(eq,-,$(substr,$(getvar,dwgname),$(-,$(strlen,$(getvar,dwgname)),7),1)),$(substr,$(getvar,dwgname),$(-,$(strlen,$(getvar,dwgname)),6),3),$(if,$(eq,-,$(substr,$(getvar,dwgname),$(-,$(strlen,$(getvar,dwgname)),8),1)),$(substr,$(getvar,dwgname),$(-,$(strlen,$(getvar,dwgname)),7),4)))))
However, it would appear that there is indeed a limit on the length of a DIESEL expression, at which point this task becomes impossible to achieve with DIESEL.
I'm afraid that's as far as I am willing to take this, it's been an interesting ride  :lol:
DIW_CADtech
« Reply #18 on: October 23, 2014, 12:21:36 AM »
Mr. Lee is correct..
The DIESEL code to check 3 Characters is approx 430 char long
DIESEL max char length is 460
Even if you left out the last check and simply posted the last 4 characters.. you would need 505 char in your script
a 6 character parce would take ~830  again assuming you just assume and post on the 6 without the check
I did not know any DIESEL code befor I started, and now I know some...
Thanks To Mr. Lee Mac and Ron Jon..
For those looking to attempt this.. with no Knowledge.. this is how I learned... see attachments..
DIW_CADtech
« Reply #19 on: October 23, 2014, 12:27:34 AM »
I would like to know if the LISP Mr. Lee Mac supplied could be modified to run by command instead of automating it thru the acaddoc.lsp.  I do not think I will be given access.. and since we have multiple clients.. I don't see a way of me talking my CAD Manager into this...
Mr. Lee..
I've asked a lot of you in the last few days... I hope I'm not going too far...
I tried to play with the code myself and it did not work.
I've attached a DWG and my edited verson of Mr. Lee's Code.
« Reply #20 on: October 23, 2014, 04:45:41 AM »
Sorry, but what do you mean by 'run by command'?
With the current code, the user can already type the command 'test' at the command-line to run the program.
I haven't checked the block name & tags against your drawing, but after a cursory glance, there is a stray 'A' in the code modified version of the code:
tag  (mapcar 'strcase tag)A
DIW_CADtech
« Reply #21 on: October 23, 2014, 11:35:21 AM »
Thank you,
Still very new to code. I must have fat fingered that in...
DIW_CADtech
« Reply #22 on: October 23, 2014, 11:50:24 AM »
I had assumed this was the type of lisp that would auto run upon opening the dwg.   In the code  I saw "(defun c:test"
I after loading I tried to run the LSP by typing in c:test.. and I got "Unknown command"
I may not get permissions to edit the acaddoc.lsp  .  Since the DIESEL code is clearly not an option.. I want to try to adapt this LSP to be run by a COMAND. Forgive me if I'm using the wrong vocabulary. If I can't exicute this code/LSP by command... What do I need to do to the code to make that happen.
Also, I assumed that I needed to keep the " " around the tag names and block name in the LSP code.  I hope that is correct.
I'm trying hard to learn here, it's a bit of trial by fire...   I managed to figure my way through the DIESEL text, the more Lisp routines I work with the more I learn.. some of it is way over my head.. and sometimes I have those eureaka moments.    I hope you can appreciate my effort.
This is not a primary function of mine at work.
« Reply #23 on: October 23, 2014, 12:17:26 PM »
Just 'test' as noted above  ;-)
You can change this to whatever command name you wish to use - just change c:test to c:YourCommandHere
Correct.
No problem! - From your attachments, it appears that you understood my DIESEL code just fine, and I appreciate your efforts trying to understand the code, rather than simply copy/pasting.
Lee
DIW_CADtech
« Reply #24 on: October 23, 2014, 01:02:46 PM »
Thank you guys  ..
Love this forum...
I think this one is closed...
