Author Topic: Superelevation Attainment problem, deleting BSR  (Read 2320 times)
kenth
« on: October 16, 2014, 08:43:40 PM »
Hi.
I'm using the following outside edge shoulder treatment:
Low side - match lane slopes
High side - default slopes with maximum shoulder rollover of 7%
That is the standard my office uses.
The problem is the inner pavement starts to superelevate at the Begin Shoulder Rollover point, instead of the Reverse Crown Point (RC).
I have to manually delete all the BSR and ESR station in the tabular editor.
Is there a more automated way of doing this?
Re: Superelevation Attainment problem, deleting BSR
« Reply #1 on: October 17, 2014, 08:54:27 AM »
edit the design criteria file-better copy the one you are using and edit the copy
kenth
« Reply #2 on: October 24, 2014, 03:55:38 AM »
I have already done so prior to posting here.
I can't find anything pertaining to BCR and ESR points
« Reply #3 on: October 24, 2014, 08:32:07 AM »
what roadway type and or pivot method are you selecting?
kenth
« Reply #4 on: October 25, 2014, 03:13:34 AM »
I am using undivided crowned, center baseline pivot method.
2 lanes, and emax 8%.
