Author Topic: Arrow moves when dimension is moved?  (Read 4450 times)
Bethrine
« on: October 16, 2014, 06:14:36 PM »
Why? I've been looking and looking and I can't find a setting for it.
Re: Arrow moves when dimension is moved?
« Reply #1 on: October 17, 2014, 08:56:35 AM »
what is your DIMASO set to?
Bethrine
« Reply #2 on: October 17, 2014, 10:02:42 AM »
« Reply #3 on: October 17, 2014, 10:26:11 AM »
time to post a small sample of that file.....
Bethrine
« Reply #4 on: October 17, 2014, 11:05:25 AM »
Okay.
Bethrine
« Reply #5 on: October 17, 2014, 11:09:10 AM »
It is specifically the diameter dimensioning tool in this dwg. Radius and multileaders seem to be fine.
Okay, I did a save as, erased some stuff (company privacy) and now they seem to be working in the sample drawing.  :x
« Last Edit: October 17, 2014, 11:23:12 AM by Bethrine »
« Reply #6 on: October 17, 2014, 11:26:00 AM »
the problem does not present itself to me in your posted sample
Note I am adding the dimension thru the viewport NOT in paperspace
« Reply #7 on: October 17, 2014, 11:28:58 AM »
also works fine on the layout tab
Bethrine
« Reply #8 on: October 17, 2014, 11:29:49 AM »
Okay, I saved a copy and will rename the original, here is the original minus company info and with that pesky leader where it shouldn't be.
« Reply #9 on: October 17, 2014, 11:48:12 AM »
try this one
Bethrine
« Reply #10 on: October 17, 2014, 11:50:01 AM »
Same problem.
« Reply #11 on: October 17, 2014, 12:28:40 PM »
Same problem.
you broke it....!!!
it doesn't do that to me
« Reply #12 on: October 17, 2014, 12:30:55 PM »
move it with the grip at the arrow head end
Bethrine
« Reply #13 on: October 17, 2014, 12:33:38 PM »
Same problem.
you broke it....!!!
 :-D I probably did! lol
Moving it at the arrowhead works but then I am stuck with the length of the annotation arrow line. So it's sort of a fix.
BKT
« Reply #14 on: October 17, 2014, 12:36:02 PM »
It looks like this is a solid model - I notice that when I try to dimension a model like this using diameter if I don't pick the edge that's on the same plane as the dimension it will cause this problem.
