Author Topic: Help needed to figure out these notes is done with auto line spacing  (Read 2639 times)
jaydee
Hi. Please see attached 2010 cad files.
Can someone able to tell me how this paragraph of notes being done with auto notes spacing.
ie. everytimes user hit "Enter" to start a new note number, but Im curious how this extra line space in between notes being setup. I could not see any text edit options or settings allow for this spacing.
I got this file from unknown source.
kpblc
Re: Help needed to figure out these notes is done with auto line spacing
« Reply #1 on: October 16, 2014, 04:13:53 AM »
Try to press Shift+Enter
Sorry for my English.
« Reply #2 on: October 16, 2014, 04:30:18 AM »
 As kpblc noted.
Shift+Enter continues Paragraph.
Enter add new numbered Paragraph.
Regarding the spacing :-
In the MText Editor :
Have a play
jaydee
« Reply #3 on: October 16, 2014, 07:49:35 PM »
Thankyou Kerry.
I did tried this option and it doesn't do anything for me previously.
and it works this time thanks for pointing to where and what number to fill in.
cheers
« Reply #4 on: October 16, 2014, 07:54:28 PM »
You are welcome jaydee.
RC
« Reply #5 on: October 16, 2014, 08:05:38 PM »
sometimes I have to "Clear Line Spacing" before the new spacing takes effect.
