Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
Is there a way to change a bunch of strings at one time?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Is there a way to change a bunch of strings at one time? (Read 2012 times)
HasanCAD
Swamp Rat
on:
October 16, 2014, 03:20:20 AM »
For example
C1 > C12
C5 > C62
TOP > BOTT
AND SO ON
Logged
Sorry for my English.
Donate to Theswamp
www.sergiwa.com
HasanCAD
Swamp Rat
Re: Is there a way to change a bunch of strings at one time?
Reply #1 on:
October 16, 2014, 03:55:35 AM »
I got it
Thanks LEE
http://www.lee-mac.com/bfind.html
Logged
Donate to Theswamp
www.sergiwa.com
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Reply #2 on:
October 16, 2014, 03:59:42 AM »
Will the search string be the complete target string or will it be contained in the target string ( a substring ) ?
Will the search string and replacement string be string values or variables ?
The first thing you could do is build a reference list for your translations
I'll make some assumptions about your intent.
Code - Auto/Visual Lisp:
[Select]
setq
translationList
list
list
"C1"
"C12"
list
"C5"
"C62"
list
"TOP"
"BTM"
list
"SO"
"ON"
defun
getRef
key
cdr
assoc
key translationList
;; Test the function just to be sure
getRef
"CAT"
;;==> nil
getref
"TOP"
;;==> ("BTM")
car
getRef
"CAT"
;;==> nil
car
getRef
"C1"
;;==> "C12"
;; Now write a tester
setq
targetString
"C5"
if
setq
replacement
car
getRef targetString
setq
targetString replacement
alert
strcat
"targetString value is now
\n
targetString
Logged
HasanCAD
Swamp Rat
Reply #3 on:
October 18, 2014, 04:15:00 AM »
While start to write a lisp, comes in mind it is very hard to do.
But when Kerry reply the post comes in mind the teacher while teaching me the lesson step by step.
Thanks Kerry for your very simple and easy way.
Logged
Donate to Theswamp
www.sergiwa.com
Mesozoic relic
Seagull
Reply #4 on:
October 18, 2014, 04:21:06 AM »
Thanks HasanCAD.
I teach the same way my brain usually works ... in little steps
and I do try very hard to keep stuff simple.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
