Author Topic: Create Polyline Offset  (Read 16898 times)
Re: Create Polyline Offset
« Reply #30 on: October 17, 2014, 08:25:13 AM »
tdtboy04,
I'm trying to make sense of your results and I can't.
Did you try Test1 ?
You may need to try Test1 and Test 2 again.
Then try the commands again manually,
once using Polyline first option
and once using Polyline second option
tdtboy04
« Reply #31 on: October 17, 2014, 08:43:40 AM »
Command: test1
Select object: _Fillet
Current settings: Mode = TRIM, Radius = 5.0000
Select first object or [uNdo/Polyline/Radius/Trim/mUltiple]: Polyline Select 2D
polyline: Radius
*Invalid selection*
Expects a point or Window/Last/Crossing/BOX/Fence/WPolygon/CPolygon
; error: Function cancelled
Select 2D polyline:
2 lines were filleted
Command: test2
Select first object or [uNdo/Polyline/Radius/Trim/mUltiple]: Radius Specify
fillet radius <5.0000>: 123
Command: Polyline Unknown command "POLYLINE".  Press F1 for help.
Command: <Entity name: FFEE30C0>
 TEST2 Unknown command "TEST2".  Press F1 for help.
Command: nil
Command:  TEST2
Select object: *Cancel*
Command: f
FILLET
Current settings: Mode = TRIM, Radius = 123.0000
Select first object or [Undo/Polyline/Radius/Trim/Multiple]: poly
Select 2D polyline: r
*Invalid selection*
Select 2D polyline:
1 line was filleted
1 was too short
Command: f
FILLET
Select first object or [Undo/Polyline/Radius/Trim/Multiple]: r
Specify fillet radius <123.0000>: 5
Select 2D polyline:
The fillet command work when i specify fillet radius then poly
« Reply #32 on: October 17, 2014, 08:58:56 AM »
Just for fun,
Does this work in 2007 ??
  1. (defun c:Test3 ()
  2.   (setq pl (car (entsel))
  3.         *filletDist* 125
  4.   )
  5.   (setvar "FILLETRAD" *filletDist*)
  6.   (command "_Fillet" "Polyline" pl)
  7. )
  8.
tdtboy04
« Reply #33 on: October 17, 2014, 09:41:06 AM »
Yes , it works
Command: test3
Current settings: Mode = TRIM, Radius = 125.0000
polyline:
3 lines were filleted
Command: nil
« Last Edit: October 17, 2014, 09:47:03 AM by tdtboy04 »
« Reply #34 on: October 17, 2014, 06:15:52 PM »
In that case, make these changes to c:doit and all should be well
  1. (if (and offsetDist filletDist)
  2.     (progn
  3.           (vla-offset plineObj offsetDist)
  4.           (setvar "FILLETRAD" *filletDist*)
  5.           (command "_Fillet" "Polyline" (entlast))
  6.           (vla-delete plineObj)
  7.     )
  8.   )
« Last Edit: October 18, 2014, 12:11:15 AM by Kerry »
tdtboy04
« Reply #35 on: October 17, 2014, 11:27:46 PM »
the message
Command: doit
Start point..:
Specify next point.. (ESC) to cancel:
Specify next point.. (ESC) to cancel: *Cancel*
Offset Distance <<20.0000>>: 200
Fillet Distance <<20.0000>>: 200
_Fillet
Current settings: Mode = TRIM, Radius = 200.0000
polyline:
Command:
the code : (vla-delete plineObj) works , but the fillet command doesn't work ( like we did not select the polyline ? ).
« Last Edit: October 17, 2014, 11:40:58 PM by tdtboy04 »
« Reply #36 on: October 18, 2014, 12:14:17 AM »
The snippet was filleting the object from the test3 code.  :cry:  my bad!
change the code
 to :
  1. (command "_Fillet" "Polyline" (entlast))
tdtboy04
« Reply #37 on: October 18, 2014, 12:58:41 AM »
Finally , it works perfectly  :-)
Thank you so much , Kerry ! :angel:
This lisp so helpful for me .
edit-kdub : attachment removed.
« Last Edit: October 18, 2014, 01:38:38 AM by Kerry »
ScottMC
« Reply #38 on: December 11, 2019, 01:17:37 PM »
Using this with my A2K, This always avoided selection so I added at Line 111 and 307:
     111->>  (setq e (car (entsel "\nSelect a Polyline or Line: " )))
                   (command "convertpoly" "H" e "")
            307 -->>    (retrieve)
            (command "convertpoly" "L" f "")
ahsattarian
« Reply #39 on: November 30, 2020, 08:17:09 AM »
This Helps U :
  1. (defun c:opl ()
  2.   (defun sub1 () (cond (s1 (entdel s1) (setq s1 nil))))
  3.   (defun sub2 ()
  4.     (redraw)
  5.     (cond (s1 (entdel s1) (setq s1 nil)))
  6.     (setq side (trans side 1 normal))
  7.     (setq start nil)
  8.     (setq bulge (vla-getbulge obj param))
  9.     (if (zerop bulge)
  10.       (progn
  11.         (setq ang (- (angle pt side) (angle p1 p2) (* pi 0.5)))
  12.         (setq ofdist (* (abs (cos ang)) (distance pt side)))
  13.         (grdraw pt side 8 1)
  14.         (setq clockwise-p (< (sin (- (angle p1 side) (angle p1 p2))) -1e-14)) ;|  #clockwise  |;
  15.         (if clockwise-p
  16.           (progn
  17.             (setq start (polar p1 (- (angle p1 p2) (* pi 0.5)) ofdist))
  18.             (setq end (polar p2 (- (angle p1 p2) (* pi 0.5)) ofdist))
  19.           )
  20.           (progn
  21.             (setq start (polar p1 (+ (angle p1 p2) (* pi 0.5)) ofdist))
  22.             (setq end (polar p2 (+ (angle p1 p2) (* pi 0.5)) ofdist))
  23.           )
  24.         )
  25.       )
  26.       (progn
  27.         (setq ang (* (atan bulge) 2.0)) ;|  #bulge  |;
  28.         (setq rad (/ (distance p1 p2) (* (sin ang) 2.0)))
  29.         (setq cen (polar p1 (+ (angle p1 p2) (- (* pi 0.5) ang)) rad))
  30.         (setq ofdist (abs (- (distance cen side) (abs rad))))
  31.         (grdraw cen side 8 1)
  32.         (if (< (abs rad) (distance cen side))
  33.           (progn
  34.             (setq start (polar p1 (angle cen p1) ofdist))
  35.             (setq end (polar p2 (angle cen p2) ofdist))
  36.           )
  37.           (if (< ofdist (abs rad))
  38.             (progn
  39.               (setq start (polar p1 (angle p1 cen) ofdist))
  40.               (setq end (polar p2 (angle p2 cen) ofdist))
  41.             )
  42.           )
  43.         )
  44.       )
  45.     )
  46.     (if start
  47.       (progn
  48.         (setq method1 2)
  49.         (cond
  50.           ((= method1 1)
  51.            (if (equal (angle p1 pm) (angle pm p2) fuzzy)
  52.              (command "line" p1 p2 "")
  53.              (command "arc" p1 pm p2)
  54.            )
  55.            (setvar "peditaccept" 1)
  56.            (command "pedit" "last" "")
  57.            (command "offset" "erase" "yes" "layer" "current" ofdist (entlast) side "")
  58.            (setq s1 (entlast))
  59.            (setq obj1 (vlax-ename->vla-object s1))
  60.           )
  61.           ((= method1 2)
  62.            (setq obj1 (vlax-invoke space 'addlightweightpolyline (list (car start) (cadr start) (car end) (cadr end))))
  63.            (vla-setbulge obj1 0 bulge)
  64.            (setq s1 (vlax-vla-object->ename obj1))
  65.           )
  66.         )
  67.         (setq method2 2)
  68.         (cond ((= (vla-get-objectname obj) "AcDb2dPolyline") (setq method2 1)))
  69.         (cond
  70.           ((= method2 1) (setq w1 (nth param w1li)) (setq w2 (nth param w2li)))
  71.           ((= method2 2) (vla-getwidth obj param 'w1 'w2))
  72.         )
  73.         (setq method3 2)
  74.         (cond
  75.           ((= method3 1) (command "pedit" s1 "e" "w" w1 w2 "x" ""))
  76.           ((= method3 2) (vla-setwidth obj1 0 w1 w2))
  77.         )
  78.         (foreach prop '(elevation layer linetype linetypegeneration linetypescale lineweight normal truecolor) ;|  #matchprop  |;
  79.           (cond ((vlax-property-available-p obj prop) (vlax-put obj1 prop (vlax-get obj prop))))
  80.         )
  81.         (setq pt1 (vlax-curve-getclosestpointto s1 pt))
  82.         (grdraw pt pt1 9 1)
  83.         (grdraw side pt1 8 1)
  84.       )
  85.     )
  86.   )
  87.   (defun sub3 ()
  88.     (cond
  89.       ((= (car a) 40) (setq w1li (append w1li (list (cdr a)))))
  90.       ((= (car a) 41) (setq w2li (append w2li (list (cdr a)))))
  91.       ((= (car a) 42) (setq buli (append buli (list (cdr a)))))
  92.     )
  93.   )
  94.   (setq s1 nil)
  95.   (setq es (entsel "\n Select Pline : "))
  96.   (setq s (car es))
  97.   (setq poj (cadr es))
  98.   (setq fuzzy 1e-4)
  99.   (if (= 1 (getvar "cvport"))
  100.   )
  101.   (setvar "autosnap" 39)
  102.   (setvar "orthomode" 0) ;|  #orthomode  |;
  103.   (setvar "osmode" 0)
  104.   (while s
  105.     (redraw s 4)
  106.     (setq en (entget s))
  107.     (setq typ (strcase (cdr (assoc 0 en)) t))
  108.     (setq w1li nil)
  109.     (setq w2li nil)
  110.     (setq buli nil)
  111.     (cond
  112.       ((= typ "lwpolyline") (foreach a en (sub3)))
  113.       ((= typ "polyline")
  114.        (setq sn (entnext s))
  115.        (setq enn (entget sn))
  116.        (setq typn (cdr (assoc 0 enn)))
  117.        (while (/= typn "seqend")
  118.          (foreach a enn (sub3))
  119.          (setq sn (entnext sn))
  120.          (setq enn (entget sn))
  121.          (setq typn (strcase (cdr (assoc 0 enn)) t))
  122.        )
  123.       )
  124.     )
  125.     (setq obj (vlax-ename->vla-object s))
  126.     (setq normal (vlax-get obj 'normal)) ;|  #normal vector  |;
  127.     (setq poj (osnap poj "_nea"))
  128.     (setq pt (trans poj 1 0))
  129.     (setq param (fix (vlax-curve-getparamatpoint obj pt)))
  130.     (setq p1 (trans (vlax-curve-getpointatparam obj param) 0 normal))
  131.     (setq pm (trans (vlax-curve-getpointatparam obj (+ (float param) 0.5)) 0 normal))
  132.     (setq p2 (trans (vlax-curve-getpointatparam obj (1+ param)) 0 normal))
  133.     (setq g 1)
  134.     (while (= g 1)
  135.       (setq gr (grread t 15 0)) ;| #grread |;
  136.       (setq code (car gr))
  137.       (setq side (cadr gr))
  138.       (cond
  139.         ((= code 5) (sub1) (sub2)) ;| Bedune Click |;
  140.         ((= code 3) ;| Click Beshe |;
  141.          (sub1)
  142.          (sub2)
  143.          (setq s1 nil)
  144.          (setvar "offsetdist" ofdist)
  145.         )
  146.         ((= code 2) (redraw) (sub1) (setq g 0)) ;| Type Beshe |;
  147.         ((= code 25) (redraw) (sub1) (setq g 0)) ;| #mouse #right-click |;
  148.       )
  149.     )
  150.     (setq s1 nil)
  151.     (setq es (entsel "\n Select Pline : "))
  152.     (setq s (car es))
  153.     (setq poj (cadr es))
  154.   )
  155.   (redraw s 4)
  156.   (princ "\n *** E N D *** ")
  157. )
