Author Topic: c3d: line/curve label sequential numbering issue  (Read 2943 times)
alanjt
  • Standby for witty remark...
« on: October 15, 2014, 10:56:59 AM »
Has anyone encountered an issue when creating line/curve labels where it will count the curve numbers normally, but when it creates the lines, it also counts the curves? thus if you go from L1 to C1, it should then continue to L2, but it's actually going to L3.
Dropbox
Re: c3d: line/curve label sequential numbering issue
« Reply #1 on: October 15, 2014, 11:43:23 AM »
Yep, Known issue. Either label individually or go back and renumber. Oh, and file a support request with Autodesk. I haven't checked if this has been corrected in the newer ('14, '15) versions, but I've seen others asking about it recently on the Adesk forum.
alanjt
« Reply #2 on: October 15, 2014, 11:58:23 AM »
Ugh. Just what I didn't want to see, but exactly what I was expecting. Thank you, Jeff.
Dropbox
alanjt
« Reply #3 on: October 15, 2014, 02:30:27 PM »
Ok, I have a fix:
>Label your polyline with your normal bearing & distance or curve data labels
>select all newly created labels
>in properties palette, change line/curve styles to ones that only display the tag
>create table
>profit
Dropbox
