Author Topic: C3D 2014 & "Built in North Arrows"  (Read 12759 times)
  • Custom Title
« on: October 15, 2014, 10:48:11 AM »
Using North arrow from the "Layout Tools". Move the arrow and the viewport window moves, even if its locked. Closing the drawing and reopening fixes the problem, until it happens again. :-/
C3D 2014
Re: C3D 2014 & "Built in North Arrows"
« Reply #1 on: October 15, 2014, 10:53:32 AM »
let me test....meanwhile what is your UCSFOLLOW setting set to?
« Reply #2 on: October 15, 2014, 10:59:59 AM »
are you using the tool to LINK the north arrow to the viewport by any chance?
  • Custom Title
« Reply #3 on: October 15, 2014, 11:01:03 AM »
0 i use MVSETUP - Align - Rotate
Yes.
  • Custom Title
« Reply #4 on: October 15, 2014, 11:08:08 AM »
Erasing the arrow and inserting another works. :)
« Reply #5 on: October 15, 2014, 11:11:52 AM »
Yes.
 DONT DO THAT
  • Custom Title
« Reply #6 on: October 15, 2014, 11:13:30 AM »
Yes.
 DONT DO THAT
ummm ok, why?  isn't that the whole purpose for these arrows?
« Reply #7 on: October 15, 2014, 11:31:23 AM »
the purpose is two fold....
they can be linked to the viewport so that IF the viewport is rotated or the arrow is - then the viewport or arrow adjusts to match...
HOWEVER those arrows are TECHNICALLY  only for use with MAP BOOK Layout tabs....
For Civil 3D - sheets the North arrow should be placed/generated when creating sheets using the plan production tools.
IF
creating Map Books - Layout tools North Arrows
creating civil 3d sheets - use North Arrow as part of your plan production tools template
BlackBox
« Reply #8 on: October 15, 2014, 01:24:43 PM »
Not sure if it makes any difference, but I use a custom 'dynamic' north arrow, and use Layout Tools to link to a given Viewport, and do not experience this issue.
The linked north arrow is updated correctly when the Viewport's view is rotated, and the north arrow can be moved in paper space (within the Viewport extents?) without moving the Viewport itself... Now, there is a noticeable lag, or pause when attempting to move the north arrow, and the associated Viewport shows as selected, but it (the Viewport) is not actually moved.
Cheers
[Edit] - This ^^^ without plan production tools.
« Reply #9 on: October 15, 2014, 03:31:21 PM »
No one said you must use plan production tools.
Simply explaining the intended use and or function of those 'Layout Tools' that one sees.
I tested the Standard arrows, and also did NOT experience the issue.
So it really isn't the arrows that are the cause, just merely a symptom.
In closing your 'custom' arrow is not the cure.
alanjt
  • Standby for witty remark...
« Reply #10 on: October 15, 2014, 03:54:29 PM »
Cheers
How is your block rotation tied to the viewport?
Dropbox
  • Custom Title
« Reply #11 on: October 15, 2014, 03:55:40 PM »
It does not happen all the time.
BlackBox
« Reply #12 on: October 15, 2014, 04:35:42 PM »
The -MAPINSERTPLE Command reads a Rotation Set parameter, renamed as Map.View.Rotation.
Not sure if it makes any difference, as the online help makes no mention of it, but my custom north arrow also has a Map.NorthArrow.Scale parameter == 1.
Cheers
alanjt
« Reply #13 on: October 15, 2014, 04:51:04 PM »
Cheers
Cool. Any chance you would mind sharing your block?
Dropbox
BlackBox
« Reply #14 on: October 15, 2014, 05:09:51 PM »
Cheers
Since replacing the geometry in block editor breaks the 'dynamic' functionality needed for Viewport association (as you may already be aware if you've renamed and attempted to modify an OOTB north arrow), just email me your north arrow block, and I'll set it up for you. :angel:
Cheers
« Reply #15 on: October 15, 2014, 05:53:37 PM »
Create an AutoCAD block containing the graphical representation of the north arrow.
Use the Block Editor to create the north arrow block.
Type BE at the command line to open the Block Editor.
Specify a name for the north arrow block.
Add any desired graphics or decorations.
Define the rotation property.
On the Block Authoring Parameter Sets palette, click Rotation Set.
Right-click the resulting parameter and click Properties.
You can also type PROPERTIES at the Command prompt.
In the Properties palette, under Property Labels, change the Rotation Set to Map.View.Rotation.
AutoCAD Map 3D uses this parameter to calculate the angle of the north arrow.
To avoid displaying this property, under Misc in the Properties palette, change Show Properties to No.
To avoid displaying the grips for this property, change Number of Grips to 0.
Save the block and close the Block Editor.
Add the scale property in similar manner as above for view rotation.
BlackBox
« Reply #16 on: October 16, 2014, 07:37:09 AM »
FWIW -
I had already provided a link to the help outlining this procedure in this post.
« Reply #17 on: October 16, 2014, 08:48:04 AM »
FWIW -
That's nice...didn't see it as a link.
Not trying to 'steal your thunder'
BlackBox
« Reply #18 on: October 16, 2014, 08:50:14 AM »
FWIW -
No worries; I just like to read things with pictures. :-D
alanjt
« Reply #19 on: October 17, 2014, 03:56:15 PM »
Cheers
Cheers
I just use the generic OTB North arrow. I'll give it a look next week. I was just being lazy.
« Last Edit: October 17, 2014, 04:22:42 PM by alanjt »
Dropbox
BlackBox
« Reply #20 on: October 17, 2014, 05:05:19 PM »
See ^^^... Hooray pictures! :lol:
No worries, my friend; I'm always happy to not help.  :-D
alanjt
« Reply #21 on: October 20, 2014, 08:37:56 AM »
:coolsmiley:
Dropbox
« Reply #22 on: October 20, 2014, 09:27:33 AM »
I don't always provide
NO HELP
But when I do;
it's the Least Help you will ever get!
