Author Topic: Geometry problem: length of segments knowing the area, perimeter and width  (Read 8386 times)
Marc'Antonio Alessi
  • Marco
I have a polyline that I know:
area         = 1512499.7 ...
perimeter = 12600
width of the track = 250 (in the example)
Is it possible calculate the total length of the segments?
(as in the picture: 3000+1000+950+1100 = 6050)
irneb
It's possible to calculate mathematically, but for one thing: Your dimensions are inconsistent as to what they measure. E.g. that "700" long piece is actually ... what ... 700+250?
ribarm
  • Marko Ribar, architect
Total length = Total area / width = 1512499.7 / 250.0 = 6049.9988 ~ 6050 = 3000 + 1000 + (700+250) + 1100
M.R. on Youtube
tombu
  • ByLayer=>Not0
You are looking to select segments of a polyline and total the lengths of those segments?
Tom Beauford P.S.M.
Marc'Antonio Alessi
  • Marco
I'm sorry, you're absolutely right (i have altered the image) here are other examples:
Marc'Antonio Alessi
  • Marco
Yes, I did not think it was that simple, I hope that there are no exceptions...
Grazie mille.
Marc'Antonio Alessi
  • Marco
Re: Geometry problem: length of segments knowing the area, perimeter and width
« Reply #6 on: November 21, 2014, 08:54:37 AM »
New question: is  there a way to calculate the maximum lenght of the profile as in the examples A and B?
roy_043
  • BricsCAD 18
« Reply #7 on: November 21, 2014, 09:15:07 AM »
Why isn't the max. length of A: 3000+1000+250+1200+1100=6550?
ribarm
« Reply #8 on: November 21, 2014, 09:23:51 AM »
Roy, probably thought :
Why isn't the max. length of A: 3000+750+250+1200+1100=6300?
M.R. on Youtube
Bethrine
« Reply #9 on: November 21, 2014, 09:29:29 AM »
A: 3000+1000+(1200-250)+1100=6050
ribarm
« Reply #10 on: November 21, 2014, 09:40:05 AM »
I think the answer is : How can center polylines length be the same as those that are offset by half the width (250/2=125) ? Simply it can't be the same length - those polylines aren't colinear - they are curving in all 4 orthogonal ways (+X,-X,+Y,-Y)...
M.R. on Youtube
Bethrine
« Reply #11 on: November 21, 2014, 10:03:25 AM »
I am not a programmer. I found it interesting as a math problem. Feel free to ignore me!  :-)
Marc'Antonio Alessi
  • Marco
« Reply #12 on: November 21, 2014, 10:40:29 AM »
I asked the question too early and without considering well: is a matter for the calculation of square tubing to build the figure, is a question that I was asked but I think that the calculation of the other figures is not correct. I think the request is just to know the total length of pipe required.
So in the example top/left the length is: 1160+1050+750 = 3000
@roy_043 > Why isn't the max. length of A: 3000+1000+250+1200+1100=6550?
        maybe this is the exact calculation  A: 3000+1000+500+1200+1100=6800
Now ask other explanations.
« Reply #13 on: November 21, 2014, 10:49:37 AM »
Do you intend on making miter joints or butt joints?
owenwengerd
« Reply #14 on: November 21, 2014, 12:08:12 PM »
In that case the solution is very simple: calculate total enclosed area of the figure divided by width of the tubing.
