Author Topic: AutoCAD Latency Issue  (Read 4250 times)
Bethrine
« on: October 09, 2014, 06:49:17 PM »
I can't find the post on this but...
RC
Re: AutoCAD Latency Issue
« Reply #1 on: October 10, 2014, 08:57:59 AM »
is that STR command from the PGP or a lisp function??
If its a lisp function there maybe some other issue at play, like a blown autoload.
ChrisCarlson
« Reply #2 on: October 10, 2014, 09:49:16 AM »
2015 is a monster with latency. A few times a day I'll type DIV for divide and get distance (DI) or CO for copy and get circle  :x
Bethrine
« Reply #3 on: October 10, 2014, 10:31:19 AM »
It's not a lisp function, it was the stretch command. I am having the same issue as ChrisCarlson.  I posted because I finally remembered to get an example of it. I'm on 2014 though.
« Reply #4 on: October 10, 2014, 10:45:19 AM »
Spinny drive or SSD on your computer? I have not noticed any lag in the command line on 2015 ( or 2014). Could it be antivirus?
RC
« Reply #5 on: October 10, 2014, 11:15:05 AM »
hmmm.. try this:
Set AUTOCOMPLETEMODE to 5 or 0
or
Play with AUTOCOMPLETEDELAY to increase or decrease the auto-complete timing.
« Reply #6 on: October 10, 2014, 11:35:14 AM »
You can also mess with INPUTSEARCHOPTIONS
Bethrine
« Reply #7 on: October 10, 2014, 11:42:46 AM »
Looks like autocompletemode and inputsearch options are the same thing except one is a menu and the other is a window. I am adjusting the delay. Thanks guys!
RC
« Reply #8 on: October 10, 2014, 12:57:58 PM »
Thanks Ron, I forgot about INPUTSEARCHOPTIONS
Hope it helps Ms. Bethrine
Bethrine
« Reply #9 on: October 10, 2014, 03:02:23 PM »
So far no issues.  :-) I cut the delay time in half.
ChrisCarlson
« Reply #10 on: October 10, 2014, 03:56:32 PM »
Spiny drive, not slated for new hardware yet.  Tweaked the settings you and CADaver posted, original was 300ms cut it down to 100ms, seems to be much better so far.
« Reply #11 on: October 10, 2014, 04:04:25 PM »
Good to hear  :)
RC
« Reply #12 on: October 10, 2014, 05:00:30 PM »
thanks for the feedback
Bethrine
« Reply #13 on: October 13, 2014, 10:06:43 AM »
Where do I find that information and I will tell you.  :uglystupid2:
ChrisCarlson
« Reply #14 on: October 15, 2014, 10:25:18 AM »
Scratch that, 100ms made it worse. Bumped it up to 1000 (1s) per http://autodesk.blogs.com/between_the_lines/2013/07/autocad-tip-disable-or-delay-autocomplete.html
